Help !
Thread: Help !
    St Mary's Pennsylvania
    233
    Help !
    Trying to wire up a new coil ! I have installed an optical points thingy, having trouble with the installation of the blaster coil (40000 volts).
    The wiring loom to the original coil is on a multi plug. I have identified the + and - on the plug and have run wires to the corresponding + and - mounts on the coil.
    Tried to start it and there was a massive power drain, engine not turning and smoke from under the dash !!!
    Fellow Frogger! PUG309's Avatar
    Feb 2001
    Sydney, Australia
    231
    Are you SURE you put it in the right way round,
    btw what do you need a new coil for anyway, also smoke from the dash cannot be good
    Daniel Djuracic
    Ex UK spec 89 309
    206 XT 1.6 16V (Diablo Red)with Peugeot Lion in back windows
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Wish I could be more help but; when you speak of massive power drains followed by smoke, assuming that the polarity is right, you haven't managed to by pass a relay by any chance??
    Alan S
    233
    Hmmmm, I think the auto electrician can have a look. He's a peugeot man !
    With the high compression, racing gas and advanced timing I needed a more accurate better spark.
    Thanks guys
