604s
Results 1 to 9 of 9
Thread: 604s
    Mar 2003
    Tasmania
    1,419
    604s
    Can anyone tell me just how many 604s were imported into Australia?
    I have been told 200 and 600, but nobody seems to know for sure.
    Pugs Rule!
    403, now sold
    404, project
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,343
    Pugnut403:
    Pugrambo is probably the one to ask, since he seems the 604 expert on here.
    I'd say the number is atleast 600, since there were about 50 605s sold here and there seems to be alot more 604s around than 605s.
    In the 1980s it seemed that there were more than 10 times as many 604s around as there is 605s around now, so 200 sounds like way too few 604s for me. They're not quite that rare.
    Dave
    <small>[ 19 March 2003, 02:24 PM: Message edited by: davemcbean ]</small>
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    12,283
    i will sit down and work through for the closest number if you like but there were off the top of my head close to between 5 and 700 604's sold in this country of which at least 75% of them were leased to companies or professional people
    very few were sold to the average pug nut that happened to waltz into the showroom
    when you think the 504 was on sale at the same time and it was 1/2 the price of a 604
    list price for a 604 towards the end of it's days here in 1980 was $23 990
    albeit they were loaded with goodies but for the everyday pug nut it was too much to outlay for basically a big bodied 504
    Dave
    not really a 604 expert just spent many an hour in, under, over and around 604's
    probably more than most people have or would bother
    mind you i could just about talk 604's all day
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,223
    I wouldn't be surprised if it was more than 600, but any 'official' figure would have to be inflated by private imports, of which there seems to have been a surprising number.
    Mar 2003
    Tasmania
    1,419
    I agree that 200 seems way short of the mark. The figure was given to me by the man I bought my 604 from, but he is really a Fiat freak so I wouldn't take his Pug knowledge as gospel.
    I know of at least 5 604s in the Hobart region, but only 1 605 was ever sold down here (I know the man who bought it).
    Does anyone know if it is an easy job to convert a 604 to manual? Does the torque tube need replacing? Can I use a 504 pedal box/clutch?
    Also will a 504 servo fit a 604, as mine is knackered?
    Pugs Rule!
    403, now sold
    404, project
    12,283
    Pugnut403:
    it is easy if you have the bell housing
    use a 505 clutch as they are the same
    use the later model 504 clutch pedal and you will find that the 604 already has the shaft there for the pedal
    use a 505 clutch fluid resovior (sp?) and 505 cylinders
    drop the engine cross member down a couple of inches to allow room
    the torque tube and tail shaft are the same
    use the later model 504 gear lever (the one that bolts to the body not the torque tube)
    as for the brake servo use a 604 one or get yours rebuilt
    the later 505 ones may be the same but don't quote me on that
    604 ones are a bigger unit from the 504 ones
    the last of the bell housings i knew of have been sold so you will be looking at a few hundred now for one unless you can get one from england
    left hand drive ones are available but you can't run them with power steering in the car but they are fine if you are putting the engine into a 504
    there are a few manual ones around and i am on the trail of one at the moment that has a right hand drive bell housing in it and a BA10/5 box (that i rebuilt)
    still hunting it down though and i'm afraid that when and if i find it it will only be good as a parts car but it's worth my chasing if i can locate it
    anyway getting off the track here
    have fun with the car and if you have any queries regarding the car let me know and i'll see what i can help you with
    they are a great car when well sorted and please please please if it has the mechanical fuel pump still pumping fuel change it and put an electric pump under the tank at the rear before the car is a molten mess
    1 x 2018 3008
    9,223
    And if not a molten mess, before the engine cooks itself because you lost the water due to that fuel pump leaking...
    9,467
    Dave,
    Only the 505 turbo has the same clutch.
    I went through all this when I had my V6.
    Graham Wallis
    Hobart
    1,496
    Pugnut,
    I've got a couple of 604 servo's tucked away....send me a Private Message here if you want one...got a bit of other 604 stuff as well...I cant see myself having another 604 now...so it's all availible !!
    Ben
    PS My white '80 mod 604 has now gone to that great pug yard in the sky frown
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
