5 speed 404
Results 1 to 12 of 12
Thread: 5 speed 404
    Mar 2003
    Tasmania
    1,419
    5 speed 404
    peugeot_
    I have recently got a 1970 404. I have been told that late 404s were fitted with the BA 7/4 gearbox. Is this true?
    If so, can the BA7/5 be fitted easily? Will the BA 7/5 work from a column shift, as I want it to look stock?
    Pugs Rule!
    403, now sold
    404, project
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,343
    There'sonly realy two issue with fitting the BA7 5 speed:
    -somehow linking up the clutch slave cylinder to the master cylinder (they use different types of hydraulic lines, 404 is plastic, 5 speed is steel)
    -the gear shift
    Usually people cut a hole in the floor for the gearshift, but I think the gearbox levers could be modified to link up to the column shift linkages. This would probably mean moving the gear selection arm to the opposite side of the box and placing it's link ball higher up on the arm. the gate selection arm would also need an attachment to go to reach over the box to the other linkages. It would require some ingenuity, but I think it is possible.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    9,223
    Change the input shaft and bellhousing and you overcome the clutch problem...
    Apr 2001
    2,343
    Ray Bell:
    But aren't the gear teeth a little different?
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    9,223
    Not on the input shaft... not to my knowledge anyway.
    I'll check with Norm.
    9,223
    They're the same, Dave...
    Oct 2005
    Venlo Netherlands
    7
    Is it possible to mount a income shaft of a ba7 into a ba7/5 gearbox?
    Hobart
    1,496
    Luc,
    you wont hear back from poor ray he has been booted from here......along with all his knowledge!
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    Fellow Frogger! Pug4eva's Avatar
    581
    Quote Originally Posted by Pug_405_Mi16
    Luc,
    But on Ray Bell profile, it says : Last Activity: 4th October 2005 05:35 PM
    Offline
    In Australia: 05 206 GTi 180 and '97 406 v6
    In Lebanon: 09 C3 Exclusive
    All in Silver
    Previously '01 206 GTi
    Hobart
    1,496
    That's odd!
    His last post was in mid August though. You would think he would be getting involved in this stuff if he was able to ? Maybe he is allowed to view but not post ?
    Ben
    1973 Peugeot 504 GL
    9,467
    Quote Originally Posted by Luc van Dijck
    Is your 505 gearbox from a push rod XN motor or an OHC Sti/GTi?
    RHD 505s have a hydraulic clutch so it may just be a matter of using a RHD bellhousing.
    Graham
    Oct 2005
    Venlo Netherlands
    7
    In Holland it is very difficult to get RHD cars. In Holland there are just about 600 505's left. Most rear weel drive Pugs were exported tot Africa before they were brougt to a junkyard. Marokko, Algeria, Egypt, Nigeria and so on.
    But if the shaft of a 504 fits to a 505 gear BA7/5, I think i can solve this problem.
    But i am not shure about the spedometer drive in the gearbox. I do not have a spedometer gear with the BA7/5, but a saw that the gearweel of a BA7 and a BA7/5 are not the same. So I Think i can not use a speedemeter gear of a BA7? Or can i change both nylon weels?
    The BA7/5 was mounted to a 1986 505, but i do not know witch type.
    Graham
