URGENT: Help with 205 bottom mount
    1000+ Posts parry's Avatar
    Sydney Australia
    1,334
    Hi guys,
    My bottom engine mount is totally shattered and with the track day coming up very fast I need your advice.
    How easy is it to replace, Im worried that it is pressed in.
    Any advice is apreciated.
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:47 (16V) 2019
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    7,553
    yes, it's pressed in. Buy a new one then give me a ring.
    Sydney NSW Australia
    137
    parry:
    Hi guys,
    See Peter above - also it could be awkward either way as you may have to remove the aluminuim bracket from the engine - which means withdrawing a drive shaft. Otherwise it may be possible to cut through the old mounting, knock it out and 'press' the new mounting into place using some threaded rod - all in situ.
    I have a spare - complete with engine mounting - so you could either use this one, or use it with a new mounting so the project becomes only a change over.
    If you're interested give me a call on 0411030936
    Denis
    Sydney Australia
    1,334
    Thanks!!!!
    Denis you have mail.
    <small>[ 15 March 2003, 10:03 PM: Message edited by: parry ]</small>
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    7,553
    Either way you'll need to remove the RH drive shaft. I/we have the tool(s) for undoing the drive shaft nut. Removing the bracket, and pressing out and in the bush is the easy part.
    Sydney Australia
    1,334
    Thanks to both Peter and Denis.
    I have sorted the problem out, my mechanic friend came over and did all for me while I was at work.
    2009 207gti
    PBs:
    Oran Park: 1:27:9
