Air Filter
Results 1 to 13 of 13
Thread: Air Filter
    Fellow Frogger! MR206's Avatar
    Apr 2002
    Sydney Australia
    331
    Air Filter
    im wanting to put a air filter in my 206 but after asking the peugeot mechanic, i was told not to because it would damage the timer or somethin like that, can anyone help clarify this?
    anyone else done it to there peugeot?
    2002 China Blue Peugeot XT
    Canberra Raiders #1 Season Ticket Holder
    May 2002
    23
    i have a current model 206gti with a bmc panel filter.150dollars from european harding and modified the air intake at the bottom of the filter box small improvement on power and economy done approx 7k with out any problems.for the money iwould recomend this over apod filter.
    new zealand
    158
    how did you modify the filter box and how did you measure the improvements? cheers!
    May 2002
    23
    the gti has a flexible intake tube at the bottom of the air box which originally tucks restrictavely up into the front guard. ijust rerouted it so it recieves better intake.the standard 206 has a slightly different air box at the bottom as for measuring imprvovements i guess i could say that my throttle respone has improved.i also have a straight through muffler.not that they are major but my dash computer tells me my average consumption is around 7.4 litres per100 city cycle is as good as astandard 1.4 206
    Fellow Frogger! Reno's Avatar
    1,260
    i got a BMC carbon Dynamic air induction from Harding European. I am well impressed with their gear. they have a good setup there.
    I have noticed throttle response is abit snappier and i have a direct "ram air" induction happening, whihc means my piping runs directly from my front bar to straight to the BMC. as shown in the last pics where you can see the piping throught the mesh
    <img src="http://www.imagestation.com/picture/sraid18/p3ec72c52b12786faa04c3c89ca934258/fdcc16de.jpg" alt=" - " />
    <img src="http://www.imagestation.com/picture/sraid18/p4c4fd60a87c249087a3b85b0838ea251/fdcc16e2.jpg" alt=" - " />
    new zealand
    158
    by having a direct re-rout ie ram air - wouldnt this potentially change the settings for the engine meaning the amount of air to fuel consumption is buggered? so did you install a pod filter thus bi passing the panel filter?
    May 2002
    23
    thats the job of the air flow meter or map sensor.as for pod filters they are drawing hot air from your engine bay and decreasing your power.
    Apr 2002
    Sydney Australia
    331
    so if i put a pod filter in, will this damage my map sensor and stuff up my air/fuel ratio?
    May 2002
    23
    no.but apod filter is drawing hot air which is circulating around your engine bay.just think the cooler the air the denser the oxygen thus more power.eg does your car run better on ahot day or acool night
    1,260
    hehehehe mine goes harder on Cold nights.....
    Apr 2002
    Sydney Australia
    331
    so if i put a air filter pod in, with a duct to bring in cold air
    then dat wont be bad for the engine or the timer?
    1,260
    nope.......
    esscargo make a kit for the 206... could be worth a look!
    <img src="http://www.esscargo.com.au/assets/images/206_GTi_air_Intake_3.jpg" alt=" - " /> this might give you an idea of a pod filter sitting in your 206
    <a href="http://www.esscargo.com.au" target="_blank">www.esscargo.com.au</a> for more of their stuff
    or <a href="http://www.bmcairfilters.com" target="_blank">www.bmcairfilters.com</a> for the one i have!
    also my BMC doesn't affect my warrenty at all! NOr would a POD filter. All you are doing is helping your car breathe better.... making it not so restrictive!
    <small>[ 03 September 2002, 10:19 PM: Message edited by: Xsara ]</small>
    yorkshire england
    4
    just been reading your posts.about filters. over here if you fit a filter its a,what you call a pod filter. with a duct routing cool air from the front of the car to the filter. giving the usual improvements and induction noise. check out k&ns 57i induction kits. <a href="http://www.demon-tweeks.co.uk." target="_blank">www.demon-tweeks.co.uk.</a>
    joey
