Head clean vlaves seats
Results 1 to 3 of 3
    Fellow Frogger! AlsPug504's Avatar
    310
    I am about to undertake some porting. since I have now access to a flow bench. So I figure while the heads off I may as well do valves and the like.
    Anyone know of a good joint in melbourne that will remove & replace valves seats stems clean pressure test head for cheap! Must be to tolerance!
    Al
    <small>[ 02 January 2003, 05:51 PM: Message edited by: AlsPug504 ]</small>
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    I've used C W Engine Services Pty Ltd
    12 Beech St Nunawading 3131 (03) 9873 3800 to reco a few of my heads (and deglaze liners, grind cranks etc). For about $180, you give them a dirty head and they give it back to you stripped, bead blasted, pressure tested, new welch plugs (the 504 one behind the pump impeller may be tricky though - you may have to get an alloy disc welded in), valves and seats refaced and matched and put back together and presented to you looking like new. I recommend you take in all the bits you can such as rocker cover, rockers etc and get them to put it through their hot wash - beats the hell out of screwing about with degreaser!!
    310
    Thanks Haakon
