205 Diagnostics?
    1000+ Posts parry's Avatar
    Sydney Australia
    1,334
    205 Diagnostics?
    Hi Guys,
    I have an intermittent engine alarm coming up on my 205. Is there a dia sheet anywhere and anybody know how to use it.
    Parry
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:47 (16V) 2019
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    7,555
    If you mean the K light on the dash, I have the codes and the instructions on how to get them out of the ECU.
    Sydney Australia
    1,334
    Soft copy?
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    Sydney Australia
    1,334
    Fault codes for Bosch Motronic 1.3 Injection
    205 GTI, 405, (except MY16) up to MY93.
    (1.9 litre engine) XU9J2, XU9JAZ
    Code Description Checks
    13 Inlet air thermistor Check the relevant component
    and its wiring.
    14 Coolant temp. sensor
    21 Throttle switch (idle position)
    33 Airflow sensor
    34 Canister purge valve
    35 Trottle switch (full load position)
    42 Injectors
    15 Fuel pump relay Fuel pump controls
    31, 32 Mixture regulation Intake air leak, exhaust leak
    51 Check Lambda sensor
    52 Try with new ECU
    53 Battery voltage Check charging system; connections
    22,54 ECU Try with new ECU
    41 Vehicle speed sensor Check sensor and wiring
    Think I found them, but how do you check?
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    Sydney Australia
    1,334
    Found that answer as well
    <a href="http://www.peugeotclub.org/peugeot/files/405ecu.pdf" target="_blank">http://www.peugeotclub.org/peugeot/files/405ecu.pdf</a>
    2009 207gti
    PBs:
    Oran Park: 1:27:9
