flat spot pug
Results 1 to 9 of 9
Thread: flat spot pug
    Fellow Frogger! felixblack1's Avatar
    May 2002
    145
    flat spot pug
    hey,
    i own a pug 205gti 1.9, and i have noticed that i have a big flat spot between 3500 and 4200rpm. my air filter is clean, new plugs and leads, tried injector cleaner, and am running [BP]98octane fuel. the car also pings when the coolant gauge is just a little under 3 1/4. i owned one a few years back and it was in its prime at 3000-4000rpm??? when i say flat spot i mean you can really feel it drop off.
    when i first bought the car i found that the vacuum ignition retard system wasn't hooked up [which caused it to ping more so]
    any ideas???
    How do you go about cleaning the distributer?
    cheers
    Felix
    May 2002
    145
    anyone???
    7,552
    Does the power come back after 4200rpm?
    Are you handy with a 10mm spanner and ratchet?
    Do you own and/or know how to use a multimeter?
    May 2002
    145
    hey PeterT,
    Yes
    Yes
    and Yes.
    What do i do doc? are you thinking distributer?
    Felix
    St Mary's Pennsylvania
    233
    Have you checked the air intake pathway ?
    What condition is the air mass sensor in (or what ever its called.)
    Sometimes the distributer shaft can develope a wiggle ?
    Check the voltage between the coil and battery over the rev range, should maintain 12 v.
    Cant think of anything else.
    Good luck.
    May 2002
    North Ryde
    83
    I've never used BP fuel...Currently using Mobil Synergy 8000....If I don't use it...(optimax or other high octane fuel...) she pings and plays up in mid range . Pugs need the good juice from the newest fuel station you can find. Apart from that, check security of intake hoses including crankcase ventilation (attached to oil filler) tongue
    Simon <a href="mailto:simfit@iprimus.com.au" target="_blank">simfit@iprimus.com.au</a>
    Peugeot 306 GTi6
    Peugeot 205 GTiS2, you want it? call me 0414 996 499,
    7,552
    When 205GTi's were released in Australia, only 91 octane was available. 95/96 octane became available in the early '90s. If you need 98 to make it stop pinging, (or believe it will make a car with 8.5:1 CR run better) you've got something wrong.
    May 2002
    145
    if you mean something wrong with the car, well yes, that's the question. "what is wrong?" wink
    thanks guys, i've checked hoses, checked inlet manifold gaskets, cleaned up throttle body...
    today i changed the the fuel filter and replaced the o'rings on the injectors [as some were cracked]. i'll see how that goes.
    james, you have few good ideas. i'll check those as well
    cheers
    felix
    Apr 2002
    Tangalooma
    160
    Sounds like camshaft timing may be out a fraction, this will determine the rev range the engine makes it's power at and how much power it will make. I don't have specs on hand but it relates to where the valves are in relation to the crank and pistons. If dialed in correctly power gains of 10% are not uncommon wink . Can someone help us out with specs and a procedure for the Pug XU9J engines question I would also like to check the valve timing on the XU9J4 in my Mi16. Also does anyone know where to aquire offset keyways to adjust the cams in reference to the sprokets question
    <small>[ 11 June 2002, 04:29 PM: Message edited by: rick_b ]</small>
    Quality is remembered long after the price is forgotten!
