Rear shocks preference.
Results 1 to 13 of 13
    Aug 2005
    Liverpool NSW
    317
    Icon5 Rear shocks preference.
    im looking to get either koni ext. adj. or bilstein sprintline for the 205 rear. i know bilsteins are more expensive but for anyone that has sampled both and without the pricetag, which would you say are better?
    Puggy.
    Ipswich, Queensland.
    1,962
    I had both on my 205 GTI and I would put the Koni yellows back on again. The 205 was the first, and last car I ever put anything other than Konis on.
    '56 Renault 4CV (16TS Power)
    '62 Renault Dauphine Gordini
    '82 Renault Fuego GTX
    Aug 2005
    Athens, Greece
    661
    Quote Originally Posted by 205puggypower
    Puggy.
    The Bilstein sprints are terrible to begin with, and they only last an unpleasant 5000 km. I have limited experience with the 205 but the 106 is really similar to it. I personally like Bilstein Group N better than Koni for my 106, but it largely depends on the car's set-up. I much prefer a softer shock/stiffer spring combination and I have really stiff springs (285 lbs/inch) and 21 mm torsion bars. As for durability, I have about 45000 hard kilometers on them and I keep checking them and they have yet to fall below the spec given for the out-of the-box unit.
    Then again, you can't go wrong with Koni.
    Thanos
    Aug 2005
    Liverpool NSW
    317
    Quote Originally Posted by Thanos
    ok noting this and double-checking they're the "streetline" type. are they the same item? would you know if they're serviceable?
    Puggy.
    Aug 2005
    Liverpool NSW
    317
    on another light, i can also get a pair of aftermarket coil-overs for the rear. its only for road use but considering i have to wait the same time for the boge's or these others at a slight increase in price, would they be worth it?
    Puggy.
    Fellow Frogger! casnell's Avatar
    May 2004
    Heidelberg/melbourne
    912
    Puggy.
    Coil-overs for the rear? Howzat work?
    Edit-yes the Bilsteins should be rebuildable
    205gti
    Oct 2003
    624
    Suspension supplier doesn't know its TB rear.
    Heasman's in Sydney can supply you with some non-externally adjustable, but rebuildable (:. can be reshimmed/adjusted) Bilsteins. They're abit stiffer than the Peugeot shocks. On a damper dyno the compression line of the Bilsteins has the same gradient but the rebound line gradient is alot more constant than the slightly irratic Pug rebound line. Heasman's thought the Pug damper was pretty good but the Billy is definately better.
    I'm pretty sure they're about $300 each.
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    Quote Originally Posted by Bluey
    "...your rhymes are more average than your girlfriend's looks, and with a face like that, I hope that girl can cook...?
    Dude - f*ck teh suspention... i love the sig. Go the Hoods...
    405 Mi16 - Sold - Now back
    205 Mi16
    505 GTi
    Aug 2005
    Athens, Greece
    661
    Puggy.
    For the rear? That would be a real hat trick!
    They would work realy well for the front though, 260 - 300 lbs/inch, 30 mm lowering.
    Sprint or Streetline, it doesn't mattter much, Group N are the ones to get. Yellow Koni would be the second option but I would run them in the softest setting.
    Thanos
    Fellow Frogger! nos205gti's Avatar
    Rozelle
    333
    Icon14
    try white line at somewhere on five dock sydney just try they'r good
    Aug 2005
    Liverpool NSW
    317
    Heasman's in Sydney ....
    they're the importer and quoted me @ $240.15+ but no stock & told it might take 6-8 weeks. cheapest i can get koni's is @ $175+ in sydney but also no stock.
    Puggy.
    Aug 2005
    Liverpool NSW
    317
    are either of these Grp N? i havent been told a part number but as far as ive searched the part # i have is BSK-113. would you know if these/this is correct?
    Puggy.
    Aug 2005
    Liverpool NSW
    317
    Quote Originally Posted by nos205gti
    the only listing i got is whiteline in minto and they quoted @ $179+ & also no stock for a few weeks
    Puggy.
