engine swap
Results 1 to 19 of 19
Like Tree2Likes
Thread: engine swap
    ferntree gully
    21
    Default engine swap
    hey
    i need some information about engine swaps. i will tell u whats going on, my pug 505 SR engine is totally stuffed and beyond repair what i want to do now is put a GM 253 V8 motor in my pug what would i need to do to my pug so the V8 can run, i want to know what parts i need and everything
    i need alot of details thank you
    12,283
    Quote Originally Posted by PUG_405_7000
    hey
    you are going to need a very friendly engineer but before that you are going to have to find out if you can register the car with that engine in it
    IF you can then you are going to have to do some work to the front end to hold it up with that great lump of iron sitting in the front end and then when you have done that it may probably never ever handle the way the car should as it will be a lead tipped arrow
    you are going to need a gearbox that is going to handle the 253
    you are in for a bit of work IF you can ever drive it legally
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Dec 2002
    Menzies Creek
    2,555
    hey
    Seriously, the 253 is a boat anchor. Heavier than a 304, 308 or 350, but with much less power, much less tuning potential and uses just as much fuel. You'd be crazy to use anything smaller than the 304.
    However, you'll find that it's very easy to do the conversion. From memory, all the Australian 253s have the trimatic pattern block. If you get a bigger one, make sure that it has the trimatic pattern block.
    Then, get a 604 transmission extension housing, output shaft and speedo drive gears. Fit this to the back of the V8 trimatic. The 604 only has three planetary gears on the output shaft whereas the V8 ones have 4, so it won't be quite as strong, but it will do the trick.
    Engine mounts should be fairly straightforward. Modified XN engine mounts should be pretty close to the money on the V8 engine, otherwise a simple adaptor plate should have it in the right spot. You have about an inch movement in the diff and tailshaft if neccessary, more so if you have the swinging diff setup (pre 1984 505). Remember that in the pug, unlike in a holden, the engine mounts are only taking the weight of the engine and gyroscopic precession, not the reactive torque from the rear axle. They don't need to be heavily engineered.
    The rest of it is just connecting all the usual stuff - exhaust, cooling, electricals, fuel lines, accellerator and choke cables, etc.
    If you want to make it a manual though, you're up for a lot more heartache.
    The biggest problem though, is dealing with all that extra weight over the front axle. The 505's strong point is it's poise and balance, and you're going to seriously compromise both of them. It would be much easier, and nearly as effective, to just go out and buy a VB commodore. Then stick a Pug 2 litre in it
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    Wouldn't the Rover 3.5l V8 be a more practical option? From memory it's lighter, smaller and pretty well bullet proof. I know that the 253 is a tough unit, but as mentioned previously they weigh a lot.
    Whilst the 253 rumble would be nice, what about a Jap V6, or even a 1UZF-E Lexus V8? They're also bullet proof and fairly cheap (under $1500 as a half cut if you do your homework), in particular the Lexus V8 is very light in relation to it's size, and a dead easy 200kw.
    _____________________________________________
    505GR/GTi turbo: For sale. Cheap rally car!
    1989 405Mi16 (RIP)
    1983 505STi (RIP)
    1982 505GR (RIP)
    ferntree gully
    21
    Default thank u all
    thank u all for the information
    555
    I say the SR20DET is a better option (even though i'm not a turbo entusiast), since it keeps the whole thing compact and light, provides plenty of punch, and it's actually been done before (as reported on this very forum!). :p
    The car will retain it's french handling, carry over some japanese reliability and parts availability, provide a very simple tuning platform, be perfectly road legal, and go like stink.
    I'd love to see the look on ricer's faces as a 505 went pissing by them from the lights, BOV a flutterin'.
    1987 205 GTI - Graphite Grey - 206k km's
    1988 MR2 Supercharger - Mica Blue - 114k km's
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,537
    just ask 505_To_The_Max Im sure hes got a fair idea
    Newcastle
    380
    Quote Originally Posted by Cubits
    It's the gift that keeps on giving! I've found that the 505 is an easily controlled drift car too, provided that sufficient power is available.
    A CA18DET is also a really good option. Cheaper than an SR, but still very strong and reliable, and smaller externally.
    Bowie, I'll PM you next week sometime, as the 505 will be back in Newcastle for good, along with myself.
    1989 405Mi16 (RIP)
    1983 505STi (RIP)
    1982 505GR (RIP)
    Dec 2014
    Kuala Lumpur, Malaysia
    7
    How much is the 2005 Peugeot 607 for sale? More details please...
    Fellow Frogger! SilverGTi_6's Avatar
    Apr 2005
    865
    What about a 406 coupe V6 engine? I always wanted to do that.
    Lotus Evora
    Peugeot 308 GTi 270
    Peugeot 308 GTi 250
    1966 Volvo 122s
    Previous
    Clio 182 Cup, Lotus Sport 111, C4 VTS, RCZ, 205 GTi, Volvo C30 T5-R, Honda S2000, 206 GTi180, Lotus Elise 111R, 205 GTi 6, Manual 406 coupe, 306 GTi 6, 405 MI16 (twice!), 505 GR
    1000+ Posts driven's Avatar
    Apr 2005
    1,570
    Speak with an engineer first on what they will certify
    Cost a mate $1500 in engineers fees to power up his Commodore.
    Nothing really, the crate engine from USA cost $24,000
    They will need to inspect at each stage of the project
    Have fun, deep pockets are required
    1000+ Posts Beano's Avatar
    3,204
    Alternatively, you could buy a used engine from someone on this website (or Pugwreck) and rebuild it. SRs have a pretty simple engine. And possibly yours is not as stuffed as you think it is.....strip it down and see.
    Dec 2002
    Menzies Creek
    2,555
    Scotty
    16,754
    why on earth would anyone use a 253 ..... My old CX2400 was faster than 253 slugomatics in commonbores. If your going to the effort of an engine swap.... lookup chev crate motor on ebay. Or if your feeling wealthy, find an old commonbore with an LS series motor in it .... being all alloy there probably not hugely heavier than the existing motor.
    16,754
    Quote Originally Posted by 505 to the max View Post
    forget the rover v8 .... next to the 253 there probably one of the most gutless v8's ever made .... fuel consumption is spectacular for something that makes so little power. I have two of them here at the moment. If one died I'd go looking for a battered old rover with a small block chev or modern GM engine fitted, and move the conversion kit with V8 into mine.
    Oh Yeah, the one thing the rover v8 has going for it is the sound ...... it's almost worth feeding it silly amounts of fuel just to listen to the tunes it plays
    if you are keen to go ancient technology though .....
    Australian Land Rover Owners
    Fellow Frogger! callipygous's Avatar
    Jan 2006
    Toowoomba
    798
    Peugeot 504/505 engine swaps have been proposed and discussed on this forum plenty of times. The general consensus is the best options are:
    604/605 V6 Easiest conversion, would drop straight in. May have to relocate battery. Not hugely powerful without modifications.
    Lexus V8 Easy to source, plenty of power, modern and LIGHT (alloy) V8.
    Mazda 13B Rotary It's been done atleast once. Anybody know what happened to it?
    As for me, I opted to keep the Peugeot motor...
    Edit: I just wised up to the fact that this is a really dead thread.
    Peugeot 504 Intercooled T04 Turbo.
    1,385
    The work "Forklift" comes to mind.....
    19,218
    Quote Originally Posted by PugMonkey View Post
    Don't knock "forklifts" and don't ever forget the Coventry climax engine. I suspect the CC engines were well before your time.
    However you might remember Sir Jack Brabham who drove open wheeler race cars in 1962, 1963, 1964 and 1965, both of Brabham and Lotus origins powered with much modified Coventry climax forklift/ fire pump engines.
    6,665
    And don't forget that the venerable R12 engine was used in some bobcats!
    Agree with the verdict on the 253. My Dad had a Commodore with one in it; what a load of rubbish that engine was.
    2003 PEUGEOT 206 GTi
