Mi16 Head and sump gasket.
Results 1 to 7 of 7
    Member franco's Avatar
    Nov 2005
    82
    Default Mi16 Head and sump gasket.
    Does anyone know the approximate cost for the above two gaskets to suit a 1.9 Mi16 engine? Just want to get a rought ball-park figure to work on.
    Also, can anyone recommend an appropriate gasket compund to use on both these gaskets.
    Any help appreciated
    1991 Peugeot 405 Mi16 sports saloon
    Boge shock absorbers all round
    K&N panel
    FOR SALE: $4800 NEGOTIABLE
    http://www.aussiefrogs.com/forum/cars-sale-wanted/32141-sale-1991-405-mi16-s1-5-adelaide.html
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Quote Originally Posted by franco
    I took the sump off my engine to clean it a few months ago - there was no gasket fitted. I enquired with Eurocare, who I get parts through, and they sold me a gasket as one was listed. I didn't use it. I just cleaned the surfaces, applied gasket sealer and bolted it back in place. I have had no leaks and no problems.
    Sorry I can't help with advice about the head gasket.
    Good Luck
    7,553
    A VRS kit is approx. $250.
    Use ThreeBond 1211 on the sump.
    Nov 2005
    82
    Wow! I didn't realise the VRS kits were so cheap.
    My old Cb70 3 cyl Daihatsu engine's VRS kit was $780
    Thanks for the tip PeterT
    K&N panel
    http://www.aussiefrogs.com/forum/showthread.php?t=32141
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    $175 from Caravelle
    Dave
    Other prices i got from them: haven't rebuild yet as the 16v is still plodding on.
    VRS (including head gasket) $175.00
    Set of head bolts $55.00
    Timing belt $32.00
    Set of big end bearings, $60.00
    Set of engine liner seals $18.00
    Piston/liner/ring set. (if available Please note if these are aussie or uk spec 9.5:1 cr or 10.4:1 cr) No Current Stock
    Piston ring set $155.00
    Main crank bearings $55.00
    Bx 16V thermostat $18.00
    Water pump $75.00
    main crank seal $23.00
    front crank seal $12.50
    sump gasket $17.00
    All prices are +GST
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    It's not recommended to use any sealer on head gaskets.
    Mike
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
    Nov 2005
    82
    cheers fellas, this is really helpful.
    K&N panel
