Oil pressure sensor leaking oil
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    Default Oil pressure sensor leaking oil
    I think it is the oil pressure sensor, (under the inlet manifold - the left sensor) that is only done up finger tight and is sending a trickle of oil down the block...
    Is it ok just to do it up tight, or does it need a seal? And what size spanner would be needed? (I don't have one big enough...)
    405 Mi16 - Sold - Now back
    205 Mi16
    505 GTi
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    It should be a tapered "gas" thread and usually a 21mm spark plug spanner fits. Just tighten it.
    Alan S
    Fellow Frogger! KRISKARRERA's Avatar
    Nov 2002
    England!
    134
    I just got a new copper washer from Pug and tightened it up gently with an adjustable spanner.
    405 MI16
    170bhp
    Le lion va de la force la force!
    Dec 2005
    brisbane
    7
    writes a letter to pug engine designers and asks why they put that thing there????
