timing belt tensioner mi 16
Results 1 to 3 of 3
    Aug 2003
    nambucca heads
    11
    Default timing belt tensioner mi 16
    Help.
    Do you turn the rear tensioner clockwise or anti clockwise to tension the belt on series 1, 1.9 mi16 .
    peter a
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Anti-clockwise; both of them although with the right hand side one, which is the first one adjusted, it is usually set to its maximum, so in its case the direction may not be quite so critical.
    Alan S
    Aug 2003
    nambucca heads
    11
    Icon10
    thanks alan.
    I was doing it clockwise. all ok now.
    petera
