Whitewalls to fit an R10
    Jan 2005
    Newcastle
    76
    Default Whitewalls to fit an R10
    firstly, here is a pic of one
    http://images.google.com.au/imgres?i...lr%3D%26sa%3DN
    now i've contacted an antique tyre place, and they've said they can't get ones to fit the 10 and that i should maybe try "portawalls"
    does any1 know of where i can get traditional whitewalls for the 10? it's jus that in the pic above, they seem to be genuwine whitewalls, could be mistaken though.
    cheers
    1968 :: R10
    Jan 2005
    Newcastle
    76
    no-one got any info on this?
    1968 :: R10
    Jul 2003
    Glen Waverley Victoria
    498
    Default Latex white walls
    At the Bendigo swap two years ago there was a bloke who had turned your conventional tyres into almost any colour you wanted. The whole process was carried out with the wheels on the car. Basically he ground a few mil off the tyre and replaced it with coloured latex.From memory it took about 3-4 hours to do your car. Cost ?? - I think a 12.5mm red/white stripe cost about $40 per. Will see if I have put the info away in an accessible spot
    Those people that say I know - generally don't.
    Jan 2005
    Newcastle
    76
    thanx Ron.
    wouldn't cutting a groove in the sidewall be dangerous tho?
    1968 :: R10
    Simon's Avatar
    6,203
    Quote Originally Posted by ADZ-R10
    thanx Ron.
    Yes, don't do it! Especially on the Michelin X, ZX or XZX which have notoriously thin sidewalls!
    I think give up on having whitewalls on a 10, the portawalls are likely a thin white rubber ring that sits between the wheel rim and the outer tyre bead. They really are not suited to radial tyres whiuch have flexible sidewalls, especially if the car is going to be subject to normal road use rather than just show use. They are mainly intended for use with cars using the old style cross ply tyres which have fairly stiff sidewalls which don't flex. And no, don't go fitting cross plys to the 10 either just so you can fit it with whitewalls!
    Jan 2005
    Newcastle
    76
    thanx Simon, again, hahaha.
    O well, least now i know, thanx mate
    1968 :: R10
