406 SV Problems
Results 1 to 8 of 8
Thread: 406 SV Problems
    Member pokinacha's Avatar
    Apr 2005
    87
    Default 406 SV Problems
    Hey everybody,
    my D8 SV has been starting to jolt in acceleration. when it's at at good temp it's starting to cough through the rev range up to 4000rpm. When revs are low, 2000-3000 it surges intermitantly with pops from the back that sound like over run crackle and when it gets to about 3900 the power comes on as most SV's do.
    anyone have any idea what the prob is? I have to find out before the extended warranty runs out.
    cheers,
    Tim
    1000+ Posts kermit's Avatar
    Jun 2002
    Inner city, Brisbane
    2,335
    Could be anything from poor fuel to a bad sensor.
    Cheers Simon
    >8-]
    Rendezvous Adelaide 2005
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Apr 2005
    87
    only fuel i use is 98 Optimax, or BP Ultimate.
    Jun 2002
    2,335
    Quote Originally Posted by pokinacha
    The problem with 98RON fuels is there usage is less than 91RON, thus they can be sitting in the servo's storage tank for long periods of time gathering water.
    Cheers Simon
    >8-]
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Apr 2005
    87
    Quote Originally Posted by kermit
    Ok, how do i get rid of that?
    Ta
    Jun 2002
    2,335
    If you've got a lot of water in your fuel you'll need to drain the tank. Does the servo you fill from have a high turnover of 98? If so then it probably isn't a fuel issue, more like an engine sensor problem.
    Cheers Simon
    >8-]
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    Apr 2005
    87
    Not sure. Its the main Shell servo in Bathurst so i'd assume so.
    Fellow Frogger! Phil Whitton's Avatar
    Bargo Sthn Highlands NSW
    273
    An old method is to mix some metho (about a cup full) into the tank. It absorbs the water and cleans the lines. Havent needed to try it with the 406 but it works with the older carby type Pugs.
    Bon Chance
