Engine Info.
Thread: Engine Info.
    Dec 2004
    Los Angeles, CA. USA
    69
    Default Engine Info.
    I was wondering if someone has knowledge of a specific Renault motor, F3N 704? I'm curious what the displacement is and where these motors come from. Any info anyone has on these would help out.
    Thanks.
    Tadpole vtspaddy's Avatar
    Aug 2005
    ireland
    10
    http://www.enker.com/images/SPC-99-00.pdf heres a link with engine codes for renault try it
    Dec 2004
    69
    Thanks. It looks like an Alliance motor. I don't know that it'll help me much, I found some on ebay and thought it might replace an 1108 in a R8 for a bit more punch, but I don't know how easy it'd be to switch out.
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Quote Originally Posted by Gordinowitz
    Mmmmm interesting option gordinowitz? I haven't heard of any being done that way.
    You could mount the motor/box combo with the upper and lower wishbones ala R5 turbo 1 & 2 rear and be a pioneer Would make a quick R8 track car, but road-registering may-be a hassle.
    Are there many R16's left in the US?
    A well sorted 1300 would be good enough, no hassle breaking gearboxes in the 8 either.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Sep 2004
    Seattle
    17
    The Appliance was farr from being a tarmac-burner if you know what I mean.
    JL
    1000+ Posts Frans's Avatar
    Auckland
    1,491
    I am sure that this engine will fit the R8/R10 box. I had one of them and it was in a R9. Same as the R11. The gearboxes was interchangeable between the 1400 and 1700 motors although the ratios wasn't always suitable.
    It wasn't a tarmac burner but it had plenty torque and very driveable. Then again it can be made to be a tarmac burner. It was due to the cam that you had more torque than HP and things like that is minor obstacles.
    A few mods will be needed with exhaust and rad hoses etc. and don't forget to get a bush for the spigot shaft because the East/West motors hasn't got it, and when you fit it in line, it must be in.
    Frans
    Old enough to know better
    Young enough to do it anyway.
