Steering wheel repair
    Jul 2004
    895
    Default Steering wheel repair
    The cover on the steering wheel on my 95 405 is starting to separate from the metal core.
    The cover is not damaged but I can feel it move around the core when I grab it.
    I was wondering if any AFers have done a successful fix.
    I was thinking of inserting a long syringe so that it ran along the wheel core and slowly withdrawing it as I pump in something along the metal core. Would probably have to do two or three times as have about 100 - 125mm to secure
    Any suggestions on a better method... and what to use. araldite, silicone????
    Decca
    Present --2016 2008Outdoor / 2014 RAV4 Diesel (My utilitarian beast, now with A/T tyres...)
    Oct 2003
    canberra
    841
    Default steering wheel repair
    you are on the right track some in PCCV have used a Sikaflex product in a mastic gun injected thru a small hole in back of the loose bit of wheel cover
    from memory it spreads along about 100 to 150mm if you can get the pressure
    Perth Western Australia
    2,678
    Default Steering wheel repair.
    Further to "Alpine's" suggestion. I've heard of urethane being injected into the loose section of wheel cover. Urethane rubber is fast curing.
    What I find incredible about this steering wheel problem is that it has been ongoing since the later 504's.
    Surely they, Peugeot, must get some feedback from their service engineers throughout the world ?
    Maybe it's the French attitude that, "why should we care about a problem that shows up a few years into the cars life?"
    con
    con is offline
    sydney, nsw, australia
    498
    Quote Originally Posted by Decca
    Decca
    I have used uretane adhesive from Clark Rubber with complete success (from memory it was about $12- for a 500ml can ).
    con.....
    Jul 2004
    895
    Con ...
    Uretane. is that correct spelling?
    did you syringe it in?
    Decca
    con
    con is offline
    498
    decca,
    yes it should be urethane bond and I did syringe it in, working systematically around the circumference of the wheel. But I cannot take credit for the technique which was described by Bruce Taylor in a PCCV article a few years ago.
