Tick Tick Tick Tick Tick
Results 1 to 25 of 37
    Fellow Frogger! pips's Avatar
    Dec 2004
    Behind you
    487
    Default Tick Tick Tick Tick Tick
    I've been noticing this ticking noise. Tappet noise precisely, on my 405 Mi16 (S1.5).
    Oil levels are exact. I've been using the stuff recommended on this forum. Oil filter is good.
    The sound comes and goes, but it's definitely tappets. What else could it be? Oil pump on the way out?
    Should I drink my last beer and shoot myself in the foot?
    pips
    Ever wonder why Mad Scientist talk to themselves? They know others just wouldn't understand.
    The software said "Windows 98 or better". So I installed Linux.
    1990 405 Mi16
    7,447
    camshaft lobe wear?
    Dec 2004
    Behind you
    487
    That wouldn't happen instantly though? Would it?
    Speaking of cams, you do that sort of thing don't you?
    pipsqeek
    1990 405 Mi16
    6,248
    CHECK THAT ALL YOUR SPARK PLUGS ARE TIGHT! See my thread on this...
    2003 PEUGEOT 206 GTi
    7,447
    yes, but I wasn't trying to rake up business. I recently rebuilt an engine that someone had fitted brand new lifters to. The cam lobes were worn however and thus the source of the noise. Another 16V owner on this forum also had new lifters fitted. His mechanic had misdiagnosed big end noise! So in went new lifters and off he went. Naturally he thought the problem had been fixed, so he gave it a flogging and destroyed the bottom end. Most of the 16V lifters I've seen are still serviceable, even after 200 000+ Km. You can pull them apart, clean out the junk, lap the tops and off you go!
    Dec 2004
    Behind you
    487
    I shall check the spark plugs this weekend, which I just replaced when I did the oil, filters, etc. I torqued them to spec.
    Thanks thus far.
    pipsqeek
    1990 405 Mi16
    6,248
    Oh well, doesn't look like it's the plugs. I can vouch, though, that it does sound like 'tappet' noise or cam wear. By the way, the injectors make a light ticking sound, but it's not intermittent, so I suppose it rules them out.
    Stuey
    Dec 2004
    Behind you
    487
    Yeah.... Definitely not the injectors. It's mechanical, and I first noticed it when stopped in a street, in front of a shop with glass windows. It was ticking like mad, so I shut the engine off.
    Let it settle for 5 mins, checks oil levels, water, air filter, and even had a quick squiz at the HT leads. Then started the car again, it was fine.
    Got home, and it was ticking like mad again, I haven't driven it since, but I've been flat chat with work.
    pips
    1990 405 Mi16
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    You'll probably find it's those hydraulic tappets. The inner piston I reckon sometimes must stick a bit, I've had it on & off with mine for years, so when I next do the cambelt, I'll pop them all out, strip, clean and burp and see how it goes. Mine does it at cold start and at a certain revs so I hold it on the accelerator just above that when I start it. After about a minute it's gone and when hot there's not a muff out of it.
    Pretty major job to do for what it is unless you're in there doing something else as the cambelt has to come off and the camshaft needs to come out to access it. 2 Cotton balls, one for each ear is a better solution at this stage IMHO.
    Alan S
    Fellow Frogger! KRISKARRERA's Avatar
    Nov 2002
    England!
    134
    When I read the title I just knew this would be Mi16. Mine does it too but it's not really audible from inside the car. My engine's been rebuilt but not the cams and tappets etc, they're all on 125000 miles.
    405 MI16
    170bhp
    Le lion va de la force la force!
    Dec 2004
    Behind you
    487
    Poo!
    I just did the timing belt, literally 2000km's ago.
    1990 405 Mi16
    8,923
    I've tried all sorts of things over the years and all seem to work to an extent but nothing has totally removed it.
    Adding to what I previously posted, I have suspicions that the inner piston has a ball bearing inside it (a bit like a check valve) which in some cases may not seal and as a result the tappet will tap until it gets full of oil and it seats. I'm presently running 0W 40 oil in mine as I was interested in seeing if that stopped it but as I said, it taps for the first few minutes, then nothing. When hot with this grade of oil in it, I can honestly say it sounds the quietest of any 16V engine I think I've ever heard but when cold it sometimes gets a bit scarey.
    Try doing as I do and just slightly raise the revs until it goes out of it and see if like mine 1200 - 1500 will lose it and as soon as it gets hot, it's totally gone. After all, if it's only carrying on for the first 2 minutes every day, is it worth getting ulcers over? When the next cambelt or any similar jobs crop up and you have to be in there, worry about it then; s I say, mine's done it for years and everything's still there as it was, so don't let it become a phobia.
    Alan S
    jgp
    jgp is offline
    Member jgp's Avatar
    Apr 2004
    brisbane
    46
    Alan S
    i've noticed a tapping noise when in 1st and 2nd gear till about 2500 rpm under load say up a hill, but not in any other gear. sounds almost like a leaking exhaust gasket. car runs well doesn't miss a beat. driven once a week so i crank it over with the fuel pump fuse out till the oil pressure gets up a bit to avoid that dry rattle on startup. run penrite 15w 60 no problems.
    90 405 MI16
    96 406 ST
    8,923
    Your noise sounds very much like either a loose spark plug or a cracked manifold or a leak in the exhaust manifold gasket.
    I'd start by checking the plugs if I were you as these engines have a bit of a habit oftrying to put one through the bonnet.
    See here: Another Mi16 blows a plug out!
    Alan S
    6,248
    An indicator that it's a cracked manifold is if it's louder when cold - the cracks tend to close up more when hot.
    Hey Pips, the title of this thread reminds me of Peter Sellers and the Pink Panther movies which I watched again on the weekend, <Tick Tick Tick> "Excuse me sir, is that a berm under your bonnet...".
    Stuey
    Jul 2004
    nth balwyn, victoria
    1,428
    Quote Originally Posted by Stuey
    Stuey
    or does your derg bite?
    or when he destroys the antique piano trying to get the mace off his hand.
    the old lady say -sir youve just destroyed our piano,its a priceless stienway.
    to which clouseau says-not any mere.http://www.aussiefrogs.com/forum/ima...ons/icon12.gif
    BAZGTI
    87' 205 gti anthacite grey
    electric sunroof/tinted windows
    koni yellow adjustables/sparco strut brace.
    15" polished speedlines.
    momo steering wheel.
    Nov 2002
    England!
    134
    The "lip" where the 8 tubes go into 1 on the Mi16 xorst manifold is know to crack.
    405 MI16
    170bhp
    58
    Alan S
    Alan,
    I would be keen to know how this goes, I have a 306 which has a shocking tappet noise until warm, using penrite atm 15W60 from memory, if the 0W40 does the trick I will be dropping it asap
    Tom
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,748
    Quote Originally Posted by tcns
    That would be a bit thick I would have thought - not good for hydraulic tappets...
    8,923
    FWIW, the worst case of the tappety taps I ever heard was in an Mi16 we're presently redoing at home. it was put in as a measure to try to reduce oil consumption caused by faulty fitted valve stem seals.
    <y policy with these engines has always been to go as light a grade oil as I could and keep it clean, based on what my sons engine was like when we stripped it. long interval oil changes and treacle for lubrication certainly didn't do it any favours, but dropping back now fronm the thick stuff might have to be done in stages such as first change 10W40 then possibly 5W40 If you can get Elf Excellum (5W40 at a reasonable price, I'd be game almost to go with that as it is a very high grade product.
    Alan S
    Dec 2004
    Behind you
    487
    So, from what I gather, I might just go ahead and change the oil with some Penrite 0W40, change the filter again, and see how I go.
    I have also noticed that there is some belt slap from the timing belt being changed, it comes and goes. I know this is a common problem, but should I take it back to Paul at Gladesville Prestige over this, or is it nothing major to worry about either?
    pips
    1990 405 Mi16
    8,923
    New one on me it being common. slapping belts are loose belts; get it seen to.
    Alan S
    6,248
    It's fairly common that they 'zissss' against the cover from it slightly warping, but I've never heard of the slapping.
    58
    So time for a change of belt when you start hearing that happen or is it a tensioner thing, never done a timing belt on a pug
    Tom
    Nov 2002
    England!
    134
    Mine started slapping after my main dealer changed my belt - nearly destroyed the engine.
    405 MI16
    170bhp
