BA7/5 in Peugeot 404
Results 1 to 7 of 7
    Oct 2005
    Venlo Netherlands
    7
    Default BA7/5 in Peugeot 404
    I want to fit a 5speed gearbox in to my 404. I read that this must be possible. But i have to use the bell house of the BA7 of my 404 because the clutch of the 404 is mechanic and the bell of a 505 does not fit to the engine. The BA7 bell housing has a different way of preventing gearbox oil getting to the clutch. Is there a solution to this problem?
    9,185
    Quote Originally Posted by Luc van Dijck
    Sounds like you have an early 404 with C3 gearbox, and are trying to fit an OHC 505 gearbox!
    You would be far better off to change to a hydraulic clutch set up as you can't buy the early clutches anymore and the improvement you will get from a hydraulic (diaphragm) clutch is far greater than from the 5th speed. You will need to change the input shaft if you have a OHC gearbox but can't help you apart from that. Ray Bell has done this but he isn't on the forum anymore.
    Graham
    Oct 2005
    Venlo Netherlands
    7
    Graham
    No I have a ba7 gear box in my 1973 peug 404 and a 1800cc motor of a 504.
    9,185
    Ah, it's the 505 gearbox which has the mechanically operated clutch then?
    Graham
    Oct 2005
    Venlo Netherlands
    7
    Graham
    In my peu 404 I have a ba7 gearbox with a hydraulic clutch. The Ba7/5 comes out of a 505 and has a mechanic clutch.
    I saw also the incom shaft is different, so the bell housing is not exchangeble.
    I was olso told that the speedomeater gear would be different, a other number of theat?
    Oct 2005
    Venlo Netherlands
    7
    I read this on the holland peugeot site http://www.vandansik.nl/phpBB2/viewt...&highlight=ba7ik heb goede ervaringen met snellere overbrengingen, de wormen zijn in combinatie met het wormwiel gewoon uitwisselbaar maar wel met de juiste shims. speciaal gereedschap kan je bij mij lenen.
    hoor het wel.
    9,185
    I have recieved the following advice:
    Could you tell him that if he fits the bellhousing and input shaft from a 504 (probably after about '74 model) he will be able to use that gearbox?
    He should just check the number of teeth on the input shaft and check the mesh before he assembles it.
    Graham
