how much would a 505 engine cost
    ferntree gully
    21
    Default how much would a 505 engine cost
    i have a pug 505 SR i was woundering how much a XN1 engine would cost with a 5 speed manual gear box? My mate is woudering, is it possible to put a 5 speed manual on an automatic car like take the auto out and put the manual in, and how much would that cost?
    Fellow Frogger! Peter J's Avatar
    Jul 2003
    Dubbo NSW
    198
    Quote Originally Posted by PUG_405_7000
    I think there is an XN1 engine on Ebay (fully rebuilt) for $1600 ... unless the auction has closed by now? Motors at wreckers are around .... ?
    I know nothing of five speed boxes or conversions.
    PJ
    ferntree gully
    21
    Quote Originally Posted by Peter J
    thank you
    Fellow Frogger! 123abc's Avatar
    Feb 2005
    brisbane
    358
    thank you
    you could probabley get all the parts from a wreckers for fairly cheap.......
    auto to manual conversion, youll need....
    >flywheel
    >clutch
    >clutch mastor cylinder (im not sure if the 505 uses a line out of the brake fluid resivoir like the 504, or if the clutch mastor has its own resivoir)
    >clutch slave cylinder
    >clutch fluid line
    >clutch pedal
    >gear linkage and gear stick and rubber boots for sound/water proofing.
    and i know on the 504 you need to change the tourqe tube as well, because of the gear linkage mounts on the tourqe tube, which arnt on the auto versions.........but i dont know if the 505 is simmilar in that way, so you may need a tourqe tube too....
    Jul 2004
    CLARE SA
    2,324
    We're not making much progress here, are we?
    xn1 motor at wreckers $500, his word that it runs
    5 speed gearbox $500 - $700 if you can find one that you can have
    other stuff in 123abc's list $300 - $500
    consumeables $200
    all up about $1900 if you do all the work youselves
    Solution buy cheap 505 manual $600 - $1500 and barter, sell, buy for whatever labour, parts consumeables you need.
    All doable
    cheers ed ge
