306 - 405 wheel sizes
    Jul 2004
    895
    Default 306 - 405 wheel sizes
    Have searched AF using obvious wording but no luck
    Are the wheels on a 306 interchangeable with those on a 405?
    Tyre size seems the same, but what about offset, stud patterns etc?
    Not concerned about the 16v versions of these models.
    Decca
    Present --2016 2008Outdoor / 2014 RAV4 Diesel (My utilitarian beast, now with A/T tyres...)
    Fellow Frogger! Kyle's Avatar
    Sep 2004
    Muswellbrook
    873
    Yes they are....
    Matter of face i have gti6 wheels i no longer need if youre interested
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    Quote Originally Posted by Decca
    Decca
    Hi Decca,
    No prob with the stud pattern-almost all Pugs have a PCD of 108mm X centre bore of 65.1mm.
    Wheel sizes are the same , but offsets can be different.
    Most 306's have an offset around 18-20mm.
    405 (at least Mi16) mave an offset of around 29mm.This means your rim may foul with your the front callper.
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Member anhtu's Avatar
    Jul 2005
    victoria
    44
    I have a set of 405mi16 rims and they don't fit a 406 because of the different offset - the front calipers on the 406 are about 10mm bigger than they should be for the 406mi16 rims to fit.
    May 2001
    1,612
    Quote Originally Posted by anhtu
    Hey Anhtu,
    Don't tell me you've flogged the 405 for a 406?
    One of the frustrating aspects of each & every mode upgrade is the wheel offset compatability & 406 wheels share an offset compatibility more like the 306 (ie 20mm).
    Jeff
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    Jul 2004
    895
    sounds like there is doubt about their interchangability
    I have seen a Series 1 306 XR (I think) with 4 apparently good alloys that may be for sale at, I hope , a reasonable price that I was thinking of getting for my Series 2 405 SRi. I would only consider this if all specs are identical.
    Anyone know of a web site link for a wheel maker that will clear things up?
    Decca
