Getting engine ready to remove... (driveshafts) - Page 2
Page 2 of 2 First 12
Results 26 to 34 of 34
  1. #26
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    Thanks to an extremely competent fellow afer, the engine is now out, and the new one is hovering ready to be put in.
    I was so suprised that we got through a day without some catastrophic discovery... I guess that makes it one in a row...
    405 Mi16 - Sold - Now back
    205 Mi16
    505 GTi
  2. #27
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Did you end up cutting that rounded nut off?
    Have a poke around under there before you start to reassemble. Look at things like steering rack gaitors and anything that's a bugger to get to when the donk's back in place.
    Also give it a good healthy degrease so you're not sliding around in pile of shit and grease when you're working on it.
    Alan S
  3. #28
    al
    al is offline
    Dec 2004
    2,012
    Alan S
    I cut a fair bit of the nut off, and the rest was taken care of by jarrod and his chisel...
    As for playing with piles of shit, i think i am pretty safe. The engine is remarkably clean, but the gearbox could use a bit of a clean... The list of parts i need to replace is also reaching a decent length, but it will be worth it to have some degree of peace of mind...
    205 Mi16
    505 GTi
  4. #29
    Jul 2004
    nth balwyn, victoria
    1,428
    Quote Originally Posted by al
    i think we used up the quota getting all the other stuff off.-BAZZ
  5. #30
    al
    al is offline
    Dec 2004
    2,012
    Ok guys... No major problems yet today, (apart from me snapping the bolt in the top mount - how i don't know) but i'm having trouble getting the driveshafts in fully. The drivers side is ok, (i think) but it seems that there the passengers needs to go about 1mm further in. I would imagine that leaving it like this would result in the gearbox oil disappearing very quickly...
    I've been wiggling and pushing it for ages, but it doesn't want to cooperate.
    Is there a trick to getting it in completely? I'm guessing brute force isn't really appropriate here...
    205 Mi16
    505 GTi
  6. #31
    al
    al is offline
    Dec 2004
    2,012
    I was just thinking about this... Is it possible that the passengers driveshaft is supposed to have a small gap between it and the box? If it was flush against it wouldn't it rub things when it spins?
    205 Mi16
    505 GTi
  7. #32
    al
    al is offline
    Dec 2004
    2,012
    I'm going to continue talking to myself in the hope that this will be useful for somebody in the future...
    It turns out that the driveshaft isn't supposed to sit flush, so my ponderings were actually correct. (i know - i'm scared too...)
    Now i have wacked the wishbone back into position, but the balljoint is obscuring the hole the bolt goes through. I guess this means that i have either not hit the wishbone in far enough, or i have gone too far. Either way i will work it out tomorrow when i can make more noise...
    Anyway, the car is taking shape now. I got the gear linkages reattached tonight, and heaps of other little things are sorted. Now i just need to replace some fuel hoses, tension the clutch and accelerator cables, sort the air intake and put the wheels on... (well, at least it is that simple in my slightly alchohol hazed mind...)
    205 Mi16
    505 GTi
  8. #33
    Aug 2005
    Liverpool NSW
    317
    Al great info & great responses. im taking notes for future reference.
    Puggy.
  9. #34
    8,923
    I think the problem is that everybody's a bit like me, trying to get the head around this 1mm you're talking about.
    Any chance of a pic so we can see what you mean?
    Alan S
