Wheel Sizing
Results 1 to 8 of 8
Thread: Wheel Sizing
    Sep 2003
    105
    Default Wheel Sizing
    I just got some second hand rims for my RCS, and they are right offset/pcd, but seem to be the wrong size in the centre bore?
    Can this be rectified somehow? The rims are OZ Racing, and there appears to be a removable sleeve in the centre bore. I'm assuming I will need to contact OZ or a tyre place - but thought i'd try here first
    8,394
    Quote Originally Posted by PugS16
    Tempe Tyres have a range of alloy hub locating rings that fit the fuego hub.Pretty sure they are the same size as the clio.
    Jo
    Sep 2003
    105
    A litte further investigation says I need to get new spigot rings that fit the Clio. Will call the tyre people tomorrow
    moosey
    Guest
    Are they factory rims or aftermarket? The MkI was fitted with Ox F1 Cups ex factory.
    moosey
    Guest
    Are they factory rims or aftermarket? The MkI was fitted with Oz F1 Cups ex factory.
    Fellow Frogger! biologist's Avatar
    867
    Yep, thats the trick. A lot of aftermarket rims have little custom inserts
    that mean the rim sits snug on your hub making it easier to put bolts in
    and keep everything nice and centered. OZ wheels will fit with all the right
    bits.
    Biologist
    A
    one Megane Family
    Fellow Frogger! ClioF1's Avatar
    Mar 2005
    Western Sydney
    172
    OZ Racing wheels are supplied with a set of Spigot Rings specific to a certain centre bore size. You need to get genuine OZ Spigot Rings for the Clio's centre bore of 60.1mm.
    These guys are the Australia distributor for OZ:
    http://www.magwheelcentre.com.au/.
    If they want to charge you an arm and a leg try these guys instead:
    http://www.demon-tweeks.co.uk.
    2005 RENAULTsport Clio 182 Cup F1
    Sep 2003
    105
    Too easy. Thanks for the replies guys.
