how much would a 505 Gti engine cost?
Results 1 to 8 of 8
    ferntree gully
    21
    Default how much would a 505 Gti engine cost?
    i have a 505 and i was thinking about puting a 505 Gti engine in there and i want it to be a 5 speed manual? how much would this cost? just for the engine
    Gus
    Gus is offline
    Fellow Frogger! Gus's Avatar
    Jun 2002
    Canberra, Australia
    600
    If you buy the engine alone from a wrecker you might be up for a bit more (due to pulling costs), but if you buy a whole car around the engine it can be had cheaper. I bought a whole 505 GTI wreck (gone clutch, crud body, but OK engine + 15in rims) for $1000 a couple of years ago, and turned down a 505 Exec (GTI engine but auto box) wreck for $450 in March.
    I'd call some local Peugeot workshops and see if they have anything rusting out the back.
    ... then you just need to pull it out and put it in your 505 (assuming this is worth doing.) Be warned: some wiring is required for GTI engines (have a search on the forums for my experiences doing just that!)
    Fellow Frogger! Ranger's Avatar
    Launceston Tas
    143
    Default an engine
    Spotted this on ebay, its in Melbourne.
    http://cgi.ebay.com.au/Peugeot-504-5...QQcmdZViewItem
    Cheers Ranger.
    "The defendant is no gentleman, but that is neither here nor there. We find for the defendant, much as we dislike him." A.P. Herbert
    9,177
    Quote Originally Posted by PUG_405_7000
    I have a manual STi/GTi gearbox and everything required to convert an auto STi/GTi to manual.
    Apparently the gear box is a little noisy but the price will take this into account.
    Graham
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Wizz bang SII 5speed GTI can be got for the $4-5k mark. At these prices it should be very well looked after.
    $2k for the motor, (reco), at least. And as much again by the time you have farnarkled, (technical term), around fixing, changing and redoing the thing, (not to mention the missing skin and time).
    As a project to teach yourself Zen like patience-yes. As a run up transport option-take the pills and lie down.......
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    9,177
    I think you would find the original XN motor to have more usuable torque anyway, so probably not worth the effort.
    Graham
    ferntree gully
    21
    Default thx for the info
    Graham
    thanks for the info
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    I did exactly what you are considering, and as per usual everyone's on the money on AF. Buy a GTi and use what you can from it. The way I did it was definitely the expensive way.
    A friend conveniently had an STi with a new clutch (which it fried on the dyno, I'm so proud!) which he parted with for $600 so that was the gearbox and, clutch and slave cylinder covered.
    I bought a Feb '85 GTi Exec motor from Reno Reck (NSW Central Coast) from a written off 505. I paid a lot, but got everything except the ECU, which I didn't need anyway.
    It's not a bolt in job. Wiring? Fuel pump? Engine mounts? It's a long list which you need to research before you get started, but in my opinion it's a good upgrade. Graham makes a good point though about the torque curve. It's not the same 'little lugger' as a carby 505 or 504; needs a bit more of a stir to get moving.
    I took about double the time I had anticipated because of all the extra things I hadn't originally considered such as those listed above.
    Why the swap if I may ask?
