Bar's leaks - 75% successful - 405 Mi16
Results 1 to 17 of 17
    6,248
    Default Bar's leaks - 75% successful - 405 Mi16
    Howdy 'leaky matrix' types,
    I've now tested the Bar's Leaks solution to the coolant smell in car issue with the 405, and can report that it's much better, but not fixed. It's been in the car about a month now.
    One thing, though, is that the coolant hasn't needed topping up since I put the stuff into the system. Previously it'd need about 150-200ml a fortnight. I've now figured that tis was a combination of the coolant manifold on the back of the block, and the heater.
    However, the heater still has a slight whiff of coolant when you first switch it on - but no where near as bad. I guess there is a very slight weep still.
    Next time I change the coolant, I'll do the matrix properly. I'm thinking of taking the engine out anyway to give it (and all the hoses etc.) the once over, so the manifold thingy can wait till then...
    Stuey
    2003 PEUGEOT 206 GTi
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Stuey,
    I'd be looking more for a damp patch on the carpet as a sign rather than the leak as I'd reckon the smell of coolant will take an aweful long time to evaporate away.
    I have it in mine, but with climate control operating, it seems that it only appears very slightly and for a very short period of time just on start up.
    I'd suggest if you take it out with a view to replacing it, before you buy a new one, that you make a close inspection of the end plates and see if they are the same as the ones on the BX (ie) Held together by being clamped at the end onto a series of "O" rings, in which case, you may find it's nowhere near as expensive as you might first imagine and it can be doubly sealed as extra long term protection. Personally, I look on the original set up almost as a design fault.
    Alan S
    16,374
    Mine has always stunk in the Xantia. I however don't think it leaks. You may have a pollen filter in yours ?? I'm bloody sure the pollen filter in mine is clogged 'cos it stinks like curry... You get used to it after a while though
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,748
    Pollen filters responde well to a good sucking clean with a vacuam cleaner and a wash out with Napisan. Bugger forking out $50 odd for a new one....
    Fellow Frogger! tasgill's Avatar
    Toowoomba
    290
    My 405 dt from new had a coolant smell when the heater was first turned on. I wasn't prepared to let the local dealer pull the dash out, ( I wrongly assumed it was the heater matrix ) so it wasnt fixed under warranty. At around 200 k's the water pump was replaced, it started to leak noticeably at around 160 k's, and lo and behold the coolant smell was cured. The pump was the problem all along, weeping just enough to cause a smell, but not enough to use much water. Maybe a cup or two in a fortnight.
    At one stage I also put Bars Leak in the radiator, and found that it destroyed the radiator cap seal.
    Terry
    6,248
    Alan, I've checked the carpets, and all the 'stuff' around the heater, poking in vents etc. a few times. There's never been any wetness. Yep, I did think the smell would take a while to go.
    Shane, pollen filters respond well to a good suck out witha vaccy, leave in the sun for the day, then a blow over with Glen 20. Someone else on here said there was a proper pollen filter spray from some firm like Wurth as well. BTW the Mi doesn't have one.
    Tasgill, yeah, I was a bit reluctant to use Bar's but Alan's had a few positive stories to tell. I think the seal issue would happen if you didn't wipe all the crud off the sealing surface before putting the cap back on. Might be wrong there... Still, the coolant's gone from being lovely and perfectly clean green, to a horrible 'dam water brown'. Still not too comfortable about that, and I think about the water pump, too, with that crud (the pellets, that I assume dissolve) circulating around.
    Stuey
    7,447
    No need to pull the engine out Stuey to change the matrix. Just pull the entire dash out or cut a hole in the glove box!
    6,248
    Yeah, Peter - I was referring to the plastic coolant manifold repair! I wasn't pulling the engine for the matrix! I just reckon the engine out would be a good thing on a 155,000km car just to check everything.
    Still, I'm convinced that I'll get the matrix out without too much dismantling. When I do, I'll do a photo set of the procedure. Nude.
    Stuey
    May 2002
    canberra...
    8,748
    Quote Originally Posted by Stuey
    Thats a bit extreme... I subscribe to the "if it aint broke, dont fix it" philosophy...
    155K km is just nicely run in for a Pug engine.
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Stuey
    I bet you wish the Mi had the same heater matrix location as the R12
    FWIW - Isn't puling the engine out just to 'check everyting' a bit extreme?
    Hobart
    1,492
    hmmmmm Bar's Leaks in an Mi16......
    Hope your ready for a new radiator! I know some cowboy mechanic did the same thing in my aunts Mi16 around 4 years ago, what a mess it made of the cooling system.
    The radiator was clogged with the stuff......
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    6,248
    I had some reservations too. Alan S has looked into it quite a bit, and has done same on his BX16V.
    I can't see how it'd clog the radiator - the small bottle contains about two teaspoons of the sealing sediment in a water soluble oil. Given the cross sectional size of the radiator, it's a physical impossibility. Plus, it doesn't solidify until it contacts air.
    On saying that, though, I will probably flush the system in a while and hopefully the minor leak will remain sealed until I can do the job properly.
    As for the extreme engine out thing; nah, I like extreme sports. You guys are just poofters.
    Edit: I suppose I should explain - if you haven't owned an Mi16, you can't know just how hard it is to inspect all the hoses, belts and wiring. I'll see how I go with just the inlet manifold off, but to get to the coolant manifold at the back of the block you need to take the RHS driveshaft off anyway. Then there are the hoses that route under the RHS of the engine...
    Haakon, it's nothing to do with the miles on the engine; it's the age on all the ancillaries like hoses. And some of the wiring needs replacement (like the oil level sender wiring). You never know, I might never do it...but it's tempting. Then I can repaint the valve cover and maybe pop a clutch in there too...
    Stuey
    8,923
    I think it would be interesting to find out how many bottles of the stuff he poured into it and what condition the coolant (or water) was when it went in.
    I was at a place a couple of years back in western NSW and was asked to look at the cooling system on a Commodore. When I lifted the cap, I thought it had been filled with chocolate mousse' as I could literally scoop it out with my finger. It also had been fed a couple of bottles of some kind of stop leak to the owners knowledge and anyones guess what went on before that, so no need to guess how easily that would clog up.
    Alan S
    Hobart
    1,492
    I dont know how much was put in, I know it was while she was on a road trip in Victoria though.
    The cooling system on the car is always looked after with regular changes but the heater sprung a leak while on tour, I'd guess only 1 bottle though?
    Ben
    1973 Peugeot 504 GL
    Hobart
    1,492
    I guess my car must be over due to have the engine out at 190,000k's......
    1973 Peugeot 504 GL
    6,248
    You know what, Ben? You're a funny guy.
    Stuey
    Hobart
    1,492
    Sorry Stuey!
    Just kidding mate....
    1973 Peugeot 504 GL
