Ultra sonic cleaners??
Results 1 to 10 of 10
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Default Ultra sonic cleaners??
    Been poking around on eBay and found these:
    http://cgi.ebay.com.au/NEW-MODEL-Dua...QQcmdZViewItem
    http://cgi.ebay.com.au/Ultrasonic-Cl...QQcmdZViewItem
    Just wondered if anyone has had any experience with these or similar and if so what are the pros and cons.
    Naturally, I'm looking at them as a means to clean injectors mainly, as well as other small bits and pieces particularly electronic bits.
    Alan S
    Don't remind me!
    16,609
    My father used to work in cartographic draughting. They used a small U/S cleaner - about the size of a coffee grinder - to fix the ink pen tips which clogged up dependably. I guess this is a similar situation (tiny orifice) to the injectors.
    Occasionally, he brought it home to clean my mother's jewellery. Worked there, too. Maybe this aspect would get you brownie points?
    Regards, Adam.
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Alan
    The one we have at work does a good job, but we have had to take it back to Jaycar a few times, last time they replaced it and the new replacement unit is showing the same simptoms...
    Perhaps I justy got 2 lemons but when they are working they are brilliant. Ive cleaned Tx valves and all sorts of small things to a very good degree then finish of in a flash solvent(if it can be). It leave spark plugs brilliant too. - Chris
    ... ptui!
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Alan, I have one (just a commercial unit not an industrial unit), and it does indeed help loosen everything up, the jewellery gets done every couple of months, but I find it works better if I soak everything in jewellery cleaner first, the combo of the two works well. Also used for pen ends, glasses, shaver blades/heads and metal watch bands.
    It's not a miracle cleaner though, and the results are far from the industrial units I've seen. Heavy stuff won't move although with a bit of brushing added in it's better then scrubbing away.
    I paid around $60 which was OK for the occasional use.
    - xTc -
    Now this is a .sig
    Fellow Frogger! amcc's Avatar
    Sep 2003
    Marraweeney Victoria
    311
    the best way of cleaning injectors. sit the injector tips in ... couple of hours they ar a little bit cleaner. all day and the paint is gone and the injectors are clean i thought these machines where $100. for those prices you could start you own Af members injector cleaning. injector places charge something like $3o an injector. all you need is a flow tester and your set
    French - 92 205mi16, 87 205gti and spares
    Other - Amarok V6, Iveco Daily 50C17, Isuzu 600
    1,160
    Yeah i got a commercial one from Jaycar too...
    works great on jewelry but dunno how it'd go on much else.
    Speaking with a guy in Melb, the mechanical injectors dont really like to be ultrasonic cleaned, at $90 ea its just better to buy new ones.
    8,923
    Quote Originally Posted by nate
    If you do that, I'll pay the postage on the old ones if ya send 'em my way
    I always thought that Ultra sonic has always been the accepted way of thoroughly cleaning them but if someone can tell us why it isn't I'm sure we would be interested.
    Alan S
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Alan,
    Ultrasonic cleaners are used in Dental laboratories all the time. One of the best solvents to use is just kero, we used to use it to remove wax based polish paste form chrome cobalt and gold castings after finishing and polishing. Hot water in small tank with detergent is also great. Kero is probably the most volitlile substance I'd risk using.
    I have seen some cheap ones flogged by door to door reps and they aren't worth the scrap they are made of most of the time.
    It'd be a risk buying one over ebay. If you wanted one for injectors, that isn't it. I have used one similar, just a different colour scheme, and it wouldn't clean a dirty spoon.
    If you want a good one go to a specialist or try one of the Dental supply companies.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    farmerdave
    Guest
    Yep, if they don't clean up and spray properly with a soak in white spirits and a blowout with the air hose there is little that can be done to them. The newer replacements (brass body) seem to make the car run better, they are a significant improvement over the old steel body version.
    Aren't the Jaycar units designed to use non-flammable cleaners only??
    Farmerdave
    ade
    ade is offline
    Jul 2003
    154
    This topic came up before and I mentioned my experience with them while working for a safety equipment company. I don't know whether you would call the ones I used industrial (approximately 3 litre capacity) but they were larger than the ones on e-bay. Regardless, as long as you follow the correct sequence with readily available chemicals it is a very effective method of cleaning small orifices, such as in carb parts, injectors and even breathing apparatuses. Check out my thread, it lists how to go about it there.
