BE1 diff ratio
Results 1 to 10 of 10
Thread: BE1 diff ratio
    Fellow Frogger! casnell's Avatar
    May 2004
    Heidelberg/melbourne
    912
    Default BE1 diff ratio
    Can anyone tell me the standard final ratio, and how difficult to get a lower one? ie from what donor car?pref 4.8?
    Thanks, Chris
    205gti
    Jul 2004
    nth balwyn, victoria
    1,428
    Quote Originally Posted by casnell
    Thanks, Chris
    not sure but i have a spare standard diff that you can look at if thats any help to you.-BAZZ
    Jul 2004
    1,428
    Actuallt my 205 gti book has that info but al has it at the moment.
    ring him and he could quoyte from it.
    there is a section in the back that has all engines ,gerabox etc info in great detail.
    or you could pop over there and grab it to look at. -BAZZ
    9,177
    Thanks, Chris
    MI 16 is the one you want according to Peter T. Your first gear would be pretty useless though.
    The ultimate is the Series 3 gearbox with Mi16 diff, gives a similar first to the Series 1 but a lower second and everything else very close.
    Graham
    303
    You can buy a brand new 4.8 crown wheel and pinion set from ABMOTORSPORT. I Don't know if it would fit the BE1 as it says it's suitable for BE3. You could always change the box. It's also not cheap at 550 pounds plus a fair wack for freight and duty. Thay are made for this mob by Quaife.
    Jarrod
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    Check out Peter's page on all the combinations:
    http://www.users.bigpond.net.au/tayl...405gearing.htm
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    May 2004
    912
    Quote Originally Posted by jarrods
    Jarrod
    550 pounds maybe not...any ideas on sourcing an Mi crown wheel?Actually someone in the UK has them on spesh at 480 pounds, still a bit exy
    205gti
    May 2004
    912
    Quote Originally Posted by bazgti
    Ta Bazz, Al's library has got my book too!
    205gti
    7,446
    You should really speak with Adrian Wuillemin. As well as BE1 and BE3, there are also many combinations of gear sets which may or may not work when mixing and matching. Start looking for a BE1 Mi16 gearbox. I know you can definitely mix and match with that.
    Parry and I both use the 205GTi/4.43:1 combination. Wuillemins prefer the 4.06:1 diff.
    To answer your original question, S1/S2 are 3.94:1, S3 are 3.62:1.
    4.8:1 diffs are fitted to Peugeot commercial vans.
    9,177
    Peter, my UK spec 1.9 has a BE1 box, this would have the same ratios as the Australian Series 3 BE3? It does have a long first, close ratios, but doesn't feel all that tall geared in 5th.
    Graham
