Even Fire Twin Turbo Finished
Results 1 to 21 of 21
    Fellow Frogger! OddFireV6's Avatar
    152
    Default Even Fire Twin Turbo Finished
    My evenfire PRV V6 twin turbo is complete and running, at 8 pounds boost it is way faster than it used to be, wheel spin in first and second is very easy to achieve. Lag time is less than with the single T04 The engine was a Volvo B280 with oddfire cams from Crow. A standard dizzy is used as a trigger for the ignition, it uses a gas research carb and is gas only. Comp reduced to 8.8 to 1 and heads ported. The trimatic auto has a manual valve body, strengthened output shaft and a steel brake band piston. A high stall to 2200 rpm torque converter and the buffers have been removed from the clutch packs in the auto. The car was already lowered has an LSD and 604 brakes with green stuff pads. This was a lot of work in case anyone was wondering. A dyno check of power will be done shortly. See the photos below.
    Attached Thumbnails Attached Thumbnails Even Fire Twin Turbo Finished-even-fire-twin-turbo-engine.jpg   Even Fire Twin Turbo Finished-even-fire-twin-turbo-turbos.jpg   Even Fire Twin Turbo Finished-intercooler-505-evenfire.jpg
    OddfireV6
    504 V6 24V, 203
    12,256
    very nice
    i can see a bit clearer now as to how it would fit into a 604 bay
    be interested in the dyno figures when you get around to it
    1 x '98 306 GTi6
    Fellow Frogger! ruckus's Avatar
    Apr 2004
    491
    Think I seriously just messed myself.
    Series 1 205 Gti
    '54 VW Beetle (oval-window)
    '71 VW Beetle (big-window)
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    Looks awesome! I never knew that the PRV was such a compact engine (by V6 standards). It looks like a very neat job. I love it.
    Have you given it a good run yet? Does the fridge effect the running temps, being placed across the grill?
    Chris.
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Iknow of a few GTA owners who could do with on exactly like that.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,376
    i certinally blow my load!!!!
    need a slave? i offer myself for your purposes..
    That.. is the horniest thing i have ever seen!!.. ever.. .even more so then erarly pictures of BMW M1's .. or even Lancia EX's that is just the bee's knees!!!!!
    1000+ Posts Uga Boga's Avatar
    May 2004
    1,057
    Even for a Poo-goe, i like it!!
    407 3.0L Exclusive (2007)
    Expert 2.0L (2009)
    Laguna 2.0L dCi (2007)
    Jan 2005
    Ferntree Gully, Melbourne, Victoria
    210
    hey
    u guys should c it in its flesh, the thing is a beast..... sounds great... twin snails... its almost sexual...
    and then there is the plumbing for those snails, its like art work..
    i saw it a the pug meeting last nite...
    mike
    1972 504 Ti
    Fellow Frogger! MR604's Avatar
    May 2002
    Bathurst
    946
    That is awesome.
    Something like that would be great in the 604
    Just got to convince the missus to get a third job to finance it
    A computer lets you make more mistakes faster than any other invention in human history, with the possible exception of handguns and tequila. - Mitch Radcliffe
    Dec 2002
    2,529
    My god, it's gorgeous!
    Congratulations on a beautiful job.
    Inspiration to get my own running, now.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Aug 2002
    3,376
    can i have a go?
    Nov 2002
    2,755
    Tets driver reporting for duty
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Fellow Frogger! Tiop's Avatar
    Hunter Valley
    145
    Looks great, id love the sound of that, bet the induction note is awsome !
    what cars did the PRV engine come from, about what could you be looking at spending for a running engine ie before all the turbo work, do toy think it would be a worth while upgrade in a 505 GTi ? thinking about some type of conversion for my 505 GTi just cant decide, need soemthing to lure me away from these performance jap cars a bit
    any way great work
    "Best Signature Ever Inserted Here"
    Fellow Frogger! james h's Avatar
    Jan 2005
    Barossa Valley
    168
    Sweet, Sweet, SWEET!
    Think you better enter it in Classic Adelaide , I'd love to see this in action!
    May I ask where you were able to source the green stuff pads from?
    205,405,505,306
    Aug 2005
    Athens, Greece
    661
    THIS IS SOOOOOO OVER THE TOP!!!! Congratulations on this pioneering work. How much weight would you estimate this conversion adds to the engine? I know it is insignificant compared to the power gains, I am just curious.
    Thanos
    Fellow Frogger! 123abc's Avatar
    Feb 2005
    brisbane
    358
    i can see myself blatently copying that in my 504
    my congrats on a VERY sexy looking job you've done
    Aug 2002
    3,376
    ill say.. when i have more then 10c to rub together ill be down in your garage macking scketches measuring this that and everything..
    better trade mark your invention quick smart !
    Fellow Frogger! WRCPUG's Avatar
    May 2002
    Glen Iris, Melbourne
    1,035
    Looks like a very neat turbo conversion....piping work looks tip top.
    I know nothing really about these motors but are they a SOHC?
    Also whats the difference between the Oddfire and Evenfire????
    PEUGEOT 306 GTi6 (1997-1999 HYBRID)
    105.4kw (141HP) ATW
    2:09 Phillip Island (Toyo Street Tyres)
    2001 YAMAHA YZF-R6
    119HP
    1993 MITSUBISHI 3000GT Twin Turbo
    300BHP
    STOCK-14.006 @97.4mph HEATHCOTE
    STOCK-1:15 CALDER Long Circuit (Stock Street Tyres + Stock Pads :banghead )
    (For Sale)
    12,256
    Quote Originally Posted by WRCPUG
    yes they are SOHC
    basically
    oddfire has a 3 journal crank
    evenfire has a 6 journal crank
    timing setup for the oddfire is odd due to the crank pins
    there is a lot more to it but oddfire is common in 90deg V6's where they have 3 journal cranks
    the PRV isn't the only oddfire V6
    1 x '98 306 GTi6
    152
    Ah thanks everyone for positive comments, I’ll try to answer some of the questions.
    505 to the Max
    It has not had a good run yet but I have had a few power slides and big launches. I have never fitted up Air con and now that I have the large yet cheap Chinese intercooler there is no room for a condenser without further mods.
    Tiop
    PRVs are cheap, buy a $200 604 Peugeot, $1400 for a late B280 evenfire and a range of options in between. If you search this site or my posts you will find much info on these engines.
    Scott/Demannu I was told last night who you are and of course your dad talks about what you are up to, I'm surprised I did not realise.
    Thanos
    It weighs 1310 KG with the V6 and turbos, I suspect that there is not much in it. Also I am not a pioneer of this idea, there is another twin turbo V6 505 in Melbourne, a manual and faster than mine.
    OddfireV6
    504 V6 24V, 203
    Aug 2005
    Athens, Greece
    661
    Quote Originally Posted by OddFireV6
    Thanos
    1. 1310 kilos is really light, a hair lighter than the stock 505 V6 actually. If it were mine (my birthday is on October 18) I would put stiffer springs up front, a 3.46 LSD diff from the 505 turbo, R compounds in the rear, (all of the above to get good grip), and go prowling.
    2. First or second, you are still a pioneer. And your giving credit where it is due, your willingness to share information, and your modesty are as impressive as your twin turbo accomplishment.
    WELL DONE!
