ZDJK specs/info needed
    Aug 2005
    Athens, Greece
    661
    Default ZDJK specs/info needed
    Does anyone know what the cylinder pressures are supposed to be for a ZDJK? We are getting 180, 160, 160 and 180 psi in cylinders 1 through 4, and emissions are excellent, but I recall reading in an old post that over 200 psi was not atypical. Also any ideas about getting a bit more go out of it, especially in the 4000 to 7000 rpm range? It already has a cold air intake, stainless 4-2-1 extractors and 2 inch exhaust. Specific information regarding valves, cam etc. would be greatly appreciated. And if someone has a shop manual in electronic form, we will stop flying blind.
    Thank you
    Thanos
    7,447
    Is this a 205 with the XU9JAZ specification (DKZ engine)?
    Feb 2005
    Glen Iris
    71
    Thanos,
    180 would be considere pretty good for this engine. 160 is still OK.
    Scott
    Feb 2005
    Glen Iris
    71
    Thanos,
    180 would be considered good for this engine. 160 is still OK on the other two cylinders.
    Scott
    Aug 2005
    Athens, Greece
    661
    Peter
    It is a 505 STI with a ZDJK (2165 cc Douvrin OHC engine/ Bosch K Jetronic fuel injection) leaded fuel engine.
    Thanos
