Nasty vibration under acceleration
Results 1 to 12 of 12
    Aug 2005
    Leeds
    3
    Default Nasty vibration under acceleration
    Can anyone please help me with a problem.
    Got a Pug 306 xsi.........just lately the engine and gearbox started to shake quite badly under acceleration which tends to shake the entire car. Need to get this sorted. Haven't bumped any wheels or anything and also doesn't seem to be speed related so would tend to rule out buckled/out of balance wheels...and also not likely to be bent drive shafts. It seems to be related to how much power you put down......the more you accelerate the worse it is. It also happened too quickly to be a knackered cv joint so i have come to the conclusion it must either be the top engine mount or the bottom one on the gearbox..........anyone disagree?
    1,160
    Had the exact problem with the Clio, Gearbox mount it was!
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Sounds like engine mount, but most probably the top one. - Chris
    ... ptui!
    Feb 2005
    Glen Iris
    71
    Same problem at present with my VW Caravelle van.....in today for a new gearbox mount. This mount handles most the twisting movement in a front wheel driver vehicle. The rubber bush section was 3/4 split!!! leading to auto gear box hitting chassis. It was weird though, in that it was horrible one day, better the next etc etc.
    Pays to check all mounts though.
    Scott
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,747
    406 is showing these symptoms. Its getting a new rear mount when the rear main seal is done as it has a crack in the rubber. But as Scott mentions, its good one day, awful the next and then better again.... Will get them to assess the gearbox mount while gearbox is out, and toss in a new one if its a bit suss.
    1,160
    Told you Chris! (or does my car resemble a VW!)
    Yeah the Gbox one is under the battery in the Clio, so its a bit "too hard" for some places to check, as the battery has to be removed! (Make sure you get the code & reset the radio!)
    Feb 2005
    Glen Iris
    71
    Got the caravelle back yesterday. Much Much better. Interesting with this VW beast it has only three mounts....two top mounts (either side) to support the engine, and the bottom transmission stabiliser bar/bush mounted to the gear box. With the the transmission removed the engine pivots/swings freely suspended by the the top two engine mounts!!
    It is a ten minute job in this case to remove and replace. The bottom engine tray is removed, and the stabliser bar/bush is levers out and new one put in.
    I know this isn't a PUG, but thought it might be of interest in general terms.
    Good luck.
    Scott
    Fellow Frogger! renn_205's Avatar
    Apr 2003
    Bondi Beach, Sydney
    221
    had similar prob. was a top engine mount. both in a twin cam corrolla and the 205
    Renn
    Peugeot 205 s16
    Megane RS 225 Cup
    May 2004
    wollongong
    40
    Default shaking
    Quote Originally Posted by renn_205
    I had a shaking under hard acceleration on my 205. Checked the engine mounts and they were ok. It turned out to be the right rear swing arm bearing needed replacing as the rear right wheel was wobbling under acceleration.
    So if it is not a gearbox/ engine mount, check there.
    Fellow Frogger! pips's Avatar
    Dec 2004
    Behind you
    487
    I had a similar issue with my 405 Mi16.
    Drive shaft was bent, and the inner CV's were shot.
    I replaced these and the car accelerates smooth again. Smooth like Jessica Alba's butt. :p
    pips
    Ever wonder why Mad Scientist talk to themselves? They know others just wouldn't understand.
    The software said "Windows 98 or better". So I installed Linux.
    1990 405 Mi16
    May 2002
    canberra...
    8,747
    How the hell do you bend a driveshaft???
    Oct 2005
    1
    Hey guys, I just got my S16 and i love it . Unfortunatelly when my dad decided to buy it he didn't notice the shaking under acceleration like you have been talking about here (I don't know how!!). Any way just wondering how much this is gonna cost to get an engine mount replaced?
