Urgent part Number sought.
Results 1 to 3 of 3
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Default Urgent part Number sought.
    Quick question:
    I need a part number for the headlight element.
    Any suggestions as to what maker and Wattage low and high beams should be, (I am not necessarily a respecter of NSW ADRs for max output limits).
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Quote Originally Posted by Gamma
    Quick question:
    Gamma, is this for your 505?? or another car? But i think its H4 60Watt hi and 55Watt low, I highly recommend NARVA's PLUS range, good bright light. - Chris
    ... ptui!
    Picton NSW
    1,412
    Quote Originally Posted by CHRI'S16
    Thanks.
    I discovered a blown low beam on the way to work today and need to send a flunky down the road to get bits.
    I have not had to change a bulb in the 505 before, (3 years, not bad).
    I will give any other GTI owners one guess which side has gone and the reason for asking for the part number will become clear, (as opposed to simply taking out the bulb and wandering down to Auto cheap co).
    I hope to spend an hour or two re-bonding with it tonight. (not that changing a bulb will take an hour, its just a case of while under the bonnet we'll have a look at this and check that and clean those and looksee here whats this-kind of thing).
    2003 T5 307 HDI
    2013 LandRover90
