diesel engine injectors
    Fellow Frogger! 505604's Avatar
    Junee, NSW
    699
    Default diesel engine injectors
    Hi all
    I need to replace the injector nozzles on my XD2S. Can anyone please tell me:
    • how to identify what injectors are in the engine
    • and therefore what nozzles I need to obtain?
    • recommended places to purchase said nozzles
    • is the replacement a DIY job
    Thanks in advance for all your help
    Junee, NSW
    699
    ** Bump **
    Aug 2003
    371
    Quote Originally Posted by 505604
    Hi all
    Sorry I dont know much about diesels - but, I have noticed new injector nozzles for sale on eBay (US site) under Mercedes - & some ads say that these injectors also suit Peugeot!!! So if your lucky you may be able to get new stuff real cheap from US. I would start googling to see if your engine uses the same Bosch parts as Mercedes. Good luck.
    Aug 2002
    1,290
    Try a diesel injection specialist such as Cooma Diesel in Canberra. They will do the job for about 600$ which includes recalibrating the pump, before and after dyno testing, and as a biiiig bonus they know what they are doing. Some people also swear by Berrima Diesel, but for me Dave Webster at Cooma Diesel is the only one to touch my fuel injection work. Ring them and talk to them, I am sure you will come away impressed.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Junee, NSW
    699
    Thanks for the info, Neil.
    When I had my engine rebuilt, I had the injection pump overhauled completely (and calibrated, too), as well as the the turbo serviced etc.
    It seems that the only thing that wasn't even considered was the injectors themselves. I didn't know of the potential damage, but my 'mechanic' should have known. The joys of living in the bush
    I'll guess that you don't think that doing the injectors yourself is a DIY job, eh?
    Andrew
    WLB
    WLB is offline
    1000+ Posts WLB's Avatar
    Warragul, Vic.
    1,103
    Andrew
    It's not too difficult to remove and replace them yourself if you've got the right size spanner. Don't remember the size. A dirty big ring/open-ender, or a deep socket or strong tube spanner. I've removed them before on a couple of 505s either for cleaning and testing or replacement.
    The main thing is not to damage the end and to use new seals (washers). The trickiest part is purging the air after reinstallation. That's when you discover air leaks in the system or your filter priming diaphragm decides to crack.
    If you need a scan of the manual page, just say so.
    Good luck,
    Warwick.
