The valve stem seal trap.
Results 1 to 2 of 2
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Default The valve stem seal trap.
    Have an Mi16 apart at present that I'm trying to find enough time to finish off but discovered today a nice little trap that I thought I'd better pass on.
    I had asked previously about the similarity between the 8 and 16V versions of these engines as regards the compatability of the valve stem seals.
    Yesterday, we found the new ones I knew we had and did a detailed comparison; what a trap!!
    I've been looking at diameters and various other things as being potentially the problem but I have discovered it is in the actual shape of the metal part that sits against the head. The genuine ones have a collar that is obviously designed in such a way as to be able to be forced into poition; in other words, the first section is about 1.5 - 2 mm smaller in diameter to the bottom section, so that when you push them on, the will be a force fit and need to be driven home to be sure they are held tightly into position.
    The others, which I suspect were 8 valve variety because they look identical apart from the "swollen" area just kind of "T" out at the top almost as though a plate of some description holds them into place.
    So the word to the wise is, be 100% sure you have the correct nes before you start reassembling the engine or you'll turn what are supposed to be "seals" into what is effectively a "pump" capable of emptyting a crankcase of 5 litres of oil in 400 klms.
    If I can get a good enough pic afterwards, I'll post it so the difference can be seen.
    Alan S
    Attached Thumbnails Attached Thumbnails The valve stem seal trap.-dsc00780.jpg
    8,923
    Ref: the pic I've added to the post above.
    The left hand one is the Mi16/BX16V seal and the taper in the base can be seen.
    The other has what appears as a flat collar and this is the one that will comeadrift and act like a hydraulic pump thereby literally pumping oil down the valve stem and put a hydraulic pressure on the valve stem and pump it down the valve guide.
    They sit in that picture base to base.
    Alan S
