XN2 TI camshaft
Results 1 to 19 of 19
Thread: XN2 TI camshaft
    Aug 2005
    Athens, Greece
    661
    Default XN2 TI camshaft
    A mechanic at the local Peugeot dealership who was working on my 504 for the first time mentioned to me that the cam on the 504 TI (with the XN2 Kugelfischer injected motor) is designed around the vacuum needs of the mechanical injection system and if it was hotted up the car will not run well. Any opinions on that? Will this be true of a moderate 273 degree cam? This kid was not even born when my 73 coupe was made but he is a real wizzard with the newer cars. He managed to squeeze 168 hp out of my 16V 1600cc 106 Rallye, so I tend to take him seriously.
    Thanos
    Aug 2005
    Athens, Greece
    661
    Quote Originally Posted by Thanos
    Thanos
    Now I am answering my own posts, how lame is that! Seriously now,I got a private message regarding my question, many thanks to the sender. He agreed with my mechanic and mentioned that McBean had listed a grind in this forum that would work well with the TI. Is this the Wade A112 that McBean has listed on his site? When I called Wade last year they said it was no longer available, but I can get any grind done here in Greece. And while I am at it, does anyone have a reference for a good grind for the ZDJL? BTW, when I tried to reply to the private message my note came back as undeliverable.
    Thanos
    Thanos
    Oct 2003
    canberra
    845
    Default 504 cams
    the choice of cam in your coupe would depend on if you were retaining the injection system or going to twin sidedraft webber carbs on the 4 port (injected)head, good luck finding a manifold for the carbs!!!!
    most of the competition 504s I have seen are setup this way,
    probably for more than one reason
    good luck
    12,256
    there is not a lot you can do with the cam as the injection system relies on vacuum
    the other thing you can do it to put EFI on it or carbies and then you can do something about the cam
    you can increase the compression ratio though and that gives you some gains and give the car a good free flowing exhaust
    there is also the other option that i have seen done and that is a 2nd throttle body but you would need to look at injectors then or run a 2nd pump as well but then you are talking serious mods
    1 x '98 306 GTi6
    12,256
    Quote Originally Posted by alpine
    good luck
    the manifolds are quite easy to make but the thing to remember is the distance you need from the butterfly in the carb to the inlet valve
    when i was looking around at doing this and then did it i spoke to many people who had done this conversion many times and the best length was 7" from butterfly to valve
    1 x '98 306 GTi6
    Aug 2005
    Athens, Greece
    661
    good luck
    Carbs or EFI are not an option, the historic racing I do here forbids it. I know most everyone uses the Weber DCOE 45 whenever allowed. I got everything else going (valves, header, exhaust). What is my best cam option?
    9,185
    Thanos
    Thanos
    I had a 112 grind done last year for a 403 engine. No such thing as unavailable, if they have the specifications they can grind the camshaft.
    Don't know about the A in front though, maybe they can't recognise this, Dave has always referred to it as just a 112.
    The bad news is that I recently talked to a person who has put a 112 into his injected rally car and he wasn't happy, no better than standard.
    If you can manage it within the rules I would definitely fit an aftermarket EFI system. Second hand fuel only ECUs or the do it yourself Megasquirt system are available very cheaply and are very easy to set up.
    I have tried for years to get the Kugelfischer system to work properly and have come to the conclusion that like K-Jetronic this system has a limited service life and nowadays just isn't worth playing around with.
    I recently fitted a Megasquirt system to a ZDJL engine and the improvement was dramatic, torque down to 2000 rpm and it would rev easily to 7300! This would suggest that the standard camshaft in the ZDJL is adequate.
    Graham
    12,256
    seeing EFI was available around the time your car was made you may be able to fit it and they possibly wouldn't know the difference
    you should be able to keep most of it looking standard except for the lack of injection pump and a few wires
    you would probably save a little weight at the same time
    1 x '98 306 GTi6
    9,185
    The EFI injectors would be a dead give away though!
    Sean, I will be contacting you shortly re the Ampol, I have just about organised the sporting events, now need to get a few more display venues finalised.
    Graham
    Aug 2005
    Athens, Greece
    661
    Graham
    Many thanks Graham, I will see if I can somehow get approval for the Megasquirt in the 504 coupe. I did after all manage by changing category (from standeard to modified) to get approval to use the ignition from a 505 SR and the front brakes from a 604 although I have not done it yet. I plan to do it after I race the Greek Mille Miglia in the standard category in September.
    I am certainly buying Megasquirt for the 505 as it is my fun-only dirt road trasportation and I do not need anybody's approval. (I am assuming that an internet search will provide their contact info.) What is involved in installing the Megasquirt system system to the 504 and 505? Would I be needing additional components? Will I need to set it up on the dyno, or is my Gtech enough? (www.gtechpro.com)
    Another question: Is there a benefit to using Megasquirt for my 16V 1600cc 106 Rallye? It is already at 168 hp, revs to 8500 at a blink, but hey, power corrupts but lack of power corrupts absolutely.
    I know these are a lot of questions but I want to ask them while I have the master's ear.
    Many thanks in advance
    Thanos
    9,185
    Thanos
    Megasquirt is a simple system ideal for converting older cars to EFI so I can't see any advantage to the 106 particularly as it is going so well at the moment. There is, however, a more advanced Megasquirt system being developed at the moment, what does the 106 use presently?
    The most difficult thing with converting the 504 is to fit the EFI injectors into the inlet manifold, you will also need to fit a throttle position sensor, an inlet air temperature sensor and an oxygen sensor. If you fit injectors from certain Nissans you won't need to use a fuel rail as these are mounted individually. Of course you will need to fit an EFI fuel pump and pressure regulator, getting rid of all the original fuel plumbing.
    You can do a lot of the tuning on the road (using a lap top computer to control the ECU) by making use of the oxygen sensor to measure air/fuel mixture. Very quick to do on a dyno though.
    Have a look at the very comprehensive Megasquirt website for details.
    Graham
    Aug 2005
    Athens, Greece
    661
    Graham
    Thanks for the quick respnce Graham.
    The 106 uses the stock injection system, but the Peugeot Sport computer was reprogrammed on the dyno since it did not work as well with the reprofiled cams. I just uprated the pressure regulator to 3.5 bar. I did however have problems after extended periods at 8000 rpms, I would burn one exhaust valve (it happened four times). We retarded timing by 1.5 degrees and it has yet to happen but I haven't given it a fair chance so far.
    For the 504 is my best bet to go with DCOE 40 Webbers and an aggressive cam (280 or so), just to keep things simple, or would the Megasquirt make it so much better? Can someone suggest (or perhaps sell) a complete EFI conversion kit? I am in the dark (and in very good company here in Greece) when it comes to 504 conversions. However, I am a bit tired of tinkering with the Kugelfisher, and I may just build the coupe the way I want it to be and just buy this nice carburated 504 Berline that I found for 600 euros and use that for racing. I ALWAYS wanted a 504 four door, I think they are so beautiful, and I won't have to worry about wrecking my coupe. It is only one of two in Greece and impossible to get body parts for.
    9,185
    I would definitely go for the fuel injection.
    I have seen many Webered 504s and none have gone all that well.
    EFI is MUCH easier to tune ( a big saving in labour cost) and probably cheaper to buy as well, Weber parts are very expensive. Add to this the fuel savings with EFI.
    It would probably be easier to fit the EFI injectors to the KF manifold than to build a Weber manifold complete with distributor drive extension.
    Graham
    12,256
    the thing to remember when putting DCOE's on a TI head is to reduce the size of the inlet port
    as it stands they are too big for carbies and anything over a 40mm throat is too much
    depending on the tuning of the engine 32mm verturi is about right for these carbs as well
    1 x '98 306 GTi6
    Aug 2005
    Athens, Greece
    661
    Graham
    Thank you, Graham, I will move in that direction with the 504 when I decide to do away with the KF. (Which will be the next time it gives me I problem. I just had to change the membranes and o-ring, talk about tedious.)
    Does anyone have a list of what I need from Megasquirt for the ZDJL conversion and any tips for the installation?
    Thanos
    12,256
    Graham
    no problem Graham
    i spoke to the other fella the other day, i'll see what he has done so far and we can go from there
    1 x '98 306 GTi6
    Aug 2005
    Athens, Greece
    661
    This is a good point, Pugrambo, especially since I have increased I and E valve sizes by 2 mm. I will go with the EFI as Graham suggested. I will just have to look for a total package as the term "EFI ignoramus" is an accurate description for this Greek Peugeot maniac. All ideas in that direction will be much appreciated.
    Thanos
    12,256
    Thanos
    follow Grahams lead and check out the megasquirt site
    the other thing would be grabbing a 505GTI engine and swapping or using the parts from that on the 504 engine
    i thought about that a while ago but not knowing what your parts supplies there are like makes it hard
    1 x '98 306 GTi6
    Aug 2005
    Athens, Greece
    661
    I already sent a note to Megasquirt, both for the XN2 and the ZDJL. What type of engine is in the 505 GTI and which parts should I be using on the 504? Early STI's here had the XN1 or the 1985 K-jet, but there are no GTI's that I have seen. But please feel free to suggest away because I will be in France for Christmas in a big SUV (snowboarding trip with wife and kids, not just for parts, I am not that demented, YET) and I can go parts hunting.
    Thanos
