505 GTI/STI suspension or brake upgrades?
Results 1 to 25 of 45
    Fellow Frogger! james h's Avatar
    Jan 2005
    Barossa Valley
    168
    Default 505 GTI/STI suspension or brake upgrades?
    Any of you guys upgraded the suspension on a 505 GTI or STI? & or are bigger brake caliper/rotor/pad kits available?
    205,405,505,306
    9,185
    Quote Originally Posted by james h
    604 brakes will bolt straight on and are vented.
    Graham
    Jan 2005
    Barossa Valley
    168
    Have just put cross drilled and slotted rotors on the front. Same disc size as stock 505 issue. Would the 604 callipers work on these or are 505 disc's to small?
    205,405,505,306
    Dec 2002
    2,529
    604 calipers have no more pad area, they are just wider to accomodate the thicker, ventilated rotor of the 604. 504s and 505s rarely suffer from brake fade, 604s never do.
    If you're after more braking power, make sure all your hoses are in good nick, or replace them all with braided lines, install a 604 brake booster (tight fit, but possible), or consider adapting Volvo 264 brakes to the front.
    I towed a 504 wagon today on a car trailer behind my 1964 404 Commerciale (4 wheel drum brakes). The drive down through the Adelaide hills was.... interesting, to say the least. Took it nice and easy. I think I'll be fitting 504 discs to the front of that, and a power booster!!
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    12,256
    what are you after to do with the car ?
    if for track use then there is more that can be done but if for a daily driver you have limits
    stiffer springs in the rear and good shocks and then ensure you have good bushes in the front end and leave the springs as they are but have good shocks and use a twin sway bar setup
    by leaving the springs as standard you still get the legendary peugeot ride and bite from the front end without as much bodyroll
    1 x '98 306 GTi6
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    VN-VS Commodore calipers bolt straight on. You'll need a different hose to suit the new caliper but it's ony a short one so Pirtek etc could make one up pretty cheap.
    I haven't tried this but Stuart (Pugtech in Brisbane) said it's an easy swap. He said that it's a definite step forward in braking power. Mind you, I've only ever had cheap crappy pads on my Pugs and I've never experienced any fade.
    What's the reason for wanting to swap?
    Member eatpeople04's Avatar
    Apr 2005
    Eltham, Victoria
    116
    Quote Originally Posted by 505 to the max
    This is interesting. Is it just the caliper that is replaced? I assume that they have a larger pad area or something similar.
    And james, where were the new discs and how much if you don't mind my asking (or your telling )
    eatpeople04
    Now showing in:
    "Betty" 1997 Black 306 GTi6
    "Shaggy" 2001 Green Subaru Outback
    The Mrs. Has
    "Wags" 2006 Ash Grey 307 XSE Hdi Touring
    And for floating...
    "Korka" 1978 Red/Blue Ramsay Lynx with 327ci Chevy
    Previously:
    "Cliff the 505th" 1985 White 505 GTi
    "Clive the 505" 1983 Poo Gold? 505 STi RIP
    9,185
    I fitted these calipers to my 404 but had to have special mounts made.
    They worked well even without power assist and with 604 discs and some highly regarded Lucas pads were fade free.
    Graham
    Jan 2005
    Barossa Valley
    168
    Mark at Lion auto is where I send my cars. He rebuild the front end and replaced all that could be replaced (shocks, bairings, pads etc.). The rotors were $190- pair.
    I want a club level car and chose the 505 because of its chassis, price and strength. Once the suspension and breaking is sorted the engine/gearbox will be looked at (If I can only find a way to fit a Nissan RB30 in it!)
    * With the twin swaybars, do you use 2 GTI ones at the front and customise the links?
    * Do the commodore calipers fit straight on 505 struts with 604 rotors?
    205,405,505,306
    Dec 2002
    2,529
    Easiest way I've found to do it is to use two 504 swaybars, as well as the 504 linkages at each end. Minimal modification is required then, as the end of the 504 swaybars have flat eyelets, instead of the 90 degree bend of the 505s.
    I think that the GTi swaybars are too stiff to use two of at the front, you'll end up with massive understeer.
    Scotty
    Jan 2005
    Barossa Valley
    168
    Cool, thanks.
    In your list of cars I see you have a V6 in a 505. Did you do the transplant?
    205,405,505,306
    12,256
    the last one i did was using 2 504 bars, this time around i will be using 2 604 bars
    the 2nd bar i chop the ends off and make hangers up that also allow the 2nd to slide a little so it doesn't bind
    using standard front springs there isn't any understeer and i have done many miles with a setup like this and some very hard driving
    in the V6 504 i had this setup in i never got any understeer yet i could get oversteer whenever i wanted
    1 x '98 306 GTi6
    Newcastle
    380
    Please don't insult your 505 by fitting a motor used in a dull as ditchwater Commodore. If you want more power from your GTi then by a used T28, new computer, a $300 intercooler from Ebay (big and good value), allow $800 for IC plumbing and turbo manifold and 4-$600 for ECU fit and tune. Another $500 for injectors and fuel pressure regulator and there's an instant 150kw and (mechanically) keeping everything 'in house'.
    Probably end up cheaper than the Nissan motor transplant.
    Chris.
    Jan 2005
    Barossa Valley
    168
    The reason I suggest a nissan engine is that I know how hard it is to get hold of a BA7 and or BA10 gearboxes. All the BA7's I have wine, and I'm cautios I might damage them with more power running through them.
    Where as if I ran a nissan motor and a gearbox out of a R31 and R32 skyline with a modified attachment for the torque tube , these motors/gearboxes are cheap, strong and readily available.
    What gearbox and clutch do you run on your turbo 505?
    205,405,505,306
    Jan 2005
    Barossa Valley
    168
    & do 604 lower control arms fit straight on to a 505 to give the front some -ve camber?
    205,405,505,306
    Aug 2005
    Athens, Greece
    661
    I switched to a combination of 85w/140 gear oil (3 parts) and Slick 50 (1 part) in my BA7/4 transmission and 3.70 diff and I only get whine after really getting on it whereas before it used to whine from the get-go. The added advantage in using Slick 50 is that it contains Teflon, a dry lubricant that tends to coat the metal parts so if your oil leakes out or its lubricating function is diminished, you still get some protection. I would not use Slick 50 on my engine, though, too many places for the Teflon to go to and I am not sure I want them there.
    Thanos
    12,256
    Quote Originally Posted by Thanos
    Thanos
    you are better off running 20/40 engine oil and putting some nulon additive in
    if it is whining that bad then you may need to think about bearings for it
    1 x '98 306 GTi6
    12,256
    604 and 505 have the same lower control arms
    1 x '98 306 GTi6
    Aug 2005
    Athens, Greece
    661
    New bearings may be in the future, although the tranny was rebuilt recently. I don't have access to nulon and I have tried 20W/50 engine oil but it heats up too fast here in Greece. Others have been using moly additive and heavier oil with good luck, but I have tried several combinations and this works best in my specific situation. What is your objection to my system? Have you used the specific items, or is it an intuitive reaction? I am not being argumentative, I truly want to learn, not to justify my actions. Is it the thickness that concerns you or the Slick 50? I use "Lubrication Enineering" for my 106 Rallye tranny (and so does the entire Group N crowd here) and it's is really thick and hard to shift when cold but works really great once it heats up (it better, it costs 40 euros a liter), so I am not as hesitant as others to use thicker oils.
    My apologies to the rest of the group reading this thread, I realize this is straying away from the topic.
    Thanos
    Newcastle
    380
    I've got a BA7/5 with a standard clutch. I think people underestimate these gearboxes. I've been putting 140 or so kw through mine and probably about 240-260nm and it wines noticably, but has done so from day one. It's out of an STi which a friend owned before me, and it had covered about 210k kms, again without fault.
    I was once told that the BA7/5 is not quite as strong (as a BA10) in terms of torque rating, but I'm yet to hear of anyone destroying one. I've also had the 'box out several times since the turbo went on so I capitolised and had it checked and the oil changed each time. Not one problem, and that's from two different mechanics checking it (both Pug men I might add).
    Even with a high torque output, it's only going to break if you treat it harshly. I don't flat shift, and only drop the clutch when I need to get through an intersection quickly (or similar).
    If it breaks, I'll investigate a straight cut gear set. Until then I'm happy with what I have and trust it completely. Above all, I still get to enjoy the thought of owning a unique Pug which puts a smile on my face every time the turbo spools up, Pug gearbox and all.
    Jan 2005
    Barossa Valley
    168
    Interesting that most of the BA7's wine. I thought my other halfs 505's wine was loud until I bought the STI, (it's about as loud as a set of straight cut timing gears spinning.)
    I'll try an oil change and some additive. Castrol VMX80+slick 50 sound ok?
    205,405,505,306
    Newcastle
    380
    That's exactly what I've got in mine at the moment. It's not broken so I guess that means that it's ok for this application.
    Aug 2005
    Athens, Greece
    661
    Point of caution: Slick 50 formulation strength varies from country to country, so refer to the bottle for treatment levels. Ours is very dilute so we use 25%, but I know of areas where only 5% is needed.
    Dec 2002
    2,529
    Cool, thanks.
    In progress at the moment. Twin turbos are becoming a good option, I've become power obsessed.
    I've just finished putting a V6 into a 504 (for practice ), see My practice V6 project for a piccy of that one. It's a fairly straightforward swap, though me being me there were a lot of modifications done along the way.
    Scotty
    Jan 2005
    Barossa Valley
    168
    No one will suspect a thing! That looks like a fun piece of equipment to take up Greenhill Road.
    205,405,505,306
