205GTI - Koni on front, what on back?
Results 1 to 25 of 25
    Fellow Frogger! DJ-Studd's Avatar
    Apr 2003
    Victoria, Australia
    545
    Default 205GTI - Koni on front, what on back?
    Hi Guys,
    My (wife's) 205 has Koni's on the front. Today I took her for a drive, second drive since it's been back from having another engine fitted. The previous engine blew it and it was cheaper to get another second hand jobbie to put in.
    Anyhow, I took the car for a drive and thought I'd test the brakes, as I'd had new pads and rotors fit on the front. Hmm... the brakes should be bed in by now. The brakes are NOT what you'd expect from a new car. Almost not there then they lock... AND THE REAR OF THE CAR SWINGS OUT TO THE RIGHT, leaving me driving sideways. Booyah, that 205T16 documentary that I watched earlier today was being put to use!
    Anyone have any idea what could be causing this? I'd have thought it's because I've got stiff suspension on the front, but soft on the back, which is leaving the car sideways.
    Thanks guys!
    -- DJ
    Jul 2004
    nth balwyn, victoria
    1,428
    Quote Originally Posted by DJ-Studd
    Hi Guys,
    Thanks guys!
    -- DJ
    check your wheel bearings and torsion bar bushes for play.
    i have koni frnt and rear.
    at the mo i have the fronts on 2 setting and the rear on one.
    the only prob with the rear is you have to take the bottom bolt out to adjust it up them refit.
    this is the reason the rears are on setting one as i havnt had the time to crawl under the car,
    apart from that i dont know.....-BAZZ
    Oct 2002
    Victoria
    65
    Plenty of possiblities but it sounds like the booster vacuum line is not connected ("Almost not there ") and you have a seized rear brake pressure limiting valve ("then they lock... AND THE REAR OF THE CAR SWINGS OUT TO THE RIGHT).
    I suggest the vacuum line because of the engine swap. Do the regular brake booster tests listed in any car maintenance manual.
    I had a rear brake pressure limiting valve seize in my 205 - not good at Phillip Island, very unstable and loosing rubber on one rear tyre. I replaced both of them.
    Different pads front and rear (with the fronts being really low friction ones) will do it.
    So might having one brake circuit without brake fluid ( I think the 205's vary in design and that mine has them diagonally connected front to rear? - can't remember).
    A totally shot rear damper will promote lock-ups at that wheel but not affect braking effort on the fronts.
    Rick Dathan
    Red S3 205GTI
    Fellow Frogger! casnell's Avatar
    May 2004
    Heidelberg/melbourne
    912
    Hi Guys,
    Thanks guys!
    -- DJ
    I would have thought that combo would promote under not over-steer? sounds like brake probs not suspension...
    205gti
    May 2004
    912
    Quote Originally Posted by Rick
    Rick Dathan
    Red S3 205GTI
    Disconnecting the booster line IMExperience just increases pedal pressure, not that on/off bizzo, in fact more feel, but LOTS more pressure...
    205gti
    Apr 2003
    Victoria, Australia
    545
    Koni Yellow's are now fitted to the rear, thanks to Ray Bell.
    The car doesn't *seem* to go sideways under heavy braking, but that could just be because I didn't brake hard enough. The brakes do suck at the moment though, so I'm going to get our mechanic to give it a check over.
    One thing that I have noticed (nobody else seems to pick it up though) is that the steering is lighter to the left than it is to the right. What could be causing this?
    Ta.
    -- DJ
    Aug 2005
    Athens, Greece
    661
    Ta.
    -- DJ
    The sideways behaviour may be attributed to better rear than front brake power. This imbalance is much more evident while braking on slippery roads or during hard/panic stops. I can think of two reasons for this:
    1. A poorely adjusted front/rear power distribution to begin with, and/or
    2. The new front brakes are so weak that the rears appear stonger.
    Perhaps you should have your mechanic also look at the F/R power distribution when he checks the brakes.
    Thanos
    1,160
    Thought it was the other way around Thanos...
    More rear brake helps keep the back in... hence the Clio's have a large rear brake bias, to ensure they dont get that good ol 205 snap happening!
    I'd say its brakes, too little at the back & too much at the front, hence the front stops but the back wants to keep going any way it can!
    PS. Drive safely!
    7,447
    Are you sure its not that the rear beam roller bearings are completely stuffed?
    9,185
    Quote Originally Posted by nate
    PS. Drive safely!
    NO way!
    More rear bias will promote oversteer, that is the basis of handbrake turns.
    Graham
    1,160
    NO way!
    Graham
    hmmm thought that was due to the locking up & lack of traction, hence it doesnt come around if you put it on mildly?!? time for a drive
    Aug 2005
    Athens, Greece
    661
    Nate
    I hope you enjoyed your drive and that you did not burn too much rubber with your e-brake turns.
    This rear brakes story is not something Graham and myself just came up with, it has been well known and accepted in racing circles for a long time. Take your bicycle out for a ride and lock your rear brake only; unless you are pointing straight, the back wheel will swing out. Then do the same thing pressing both brakes and you will see that the back wheel does not swing out. It is pretty much the same way with the car; excessive rear brake pressure (relative to the front) will make the rear swing out.
    Thanos
    1000+ Posts U Turn's Avatar
    1,761
    PS. Drive safely!
    Nope. Other way around.
    edit: When will I learn to read ALL the posts before [email protected]? Thanos, the bicycle example is a good one.
    Take the long way home....
    - 306 gti6
    1,160
    Quote Originally Posted by U Turn
    No its not, i dont have a bike!!!
    Aug 2005
    Athens, Greece
    661
    Borrow one from a friend, Nate, I am sure you have many and someone will loan you one for such a good cause. BTW, what was the outcome of your test drive?
    Thanos
    7,447
    Hi Guys,
    As I said earlier, this behaviour is typical of a 205 with a worn rear beam. The needle rollers rust and turn to dust, leaving excessive and unforgiving play in the swing arms.
    Aug 2005
    brisbane
    12
    What are a set of Konis worth for a 205??
    My 205 is harder to turn right than it is Left?? Why
    I like doing skids on my bike!
    Oh yer, I also have a really loud screaching noise coming from the engine, sounds like an altenater bearing but i am pretty sure it is not. Could a cam bearing scream like this??
    Sorry for jumpin this thread. Just sound like you guys know your
    205s
    Fellow Frogger! renn_205's Avatar
    Apr 2003
    Bondi Beach, Sydney
    221
    that's what i thought/read was the cause of the rear of my 205 doing this at times i least needed it too!!! i have had the shocks and brakes checked and they are allegedly fine. so this it must be. that and i know they are stuffed
    there is a very good guide on refurbishing the rear beam on the 205gtidrivers page that makes you not want to do it! mine is still stuffed, me naughty
    Renn
    Peugeot 205 s16
    Megane RS 225 Cup
    9,185
    Quote Originally Posted by cranklounge
    205s
    Slipping alternator drive belt.
    Graham
    Fellow Frogger! biologist's Avatar
    867
    Maybe I missed it in there somewhere but is there a brake bias adjuster
    on the 205? Most front wheelers have one. It moves braking bias
    front to back as the back is loaded up, with kids, groceries etc.
    In a car I used to own a while back I had a similar problem and it turned
    out the bias adjuster hadn't been refitted after a brake overhaul...
    I reconnected it and all was well again.
    Biologist
    A
    one Megane Family
    Aug 2005
    Athens, Greece
    661
    Quote Originally Posted by biologist
    See posts 7-14, I also think it is a possibility.
    16,374
    Quote Originally Posted by renn_205
    Guys,
    you need to link the rear beam article in our common faults section... What a challenge !!! I'm almost tempted to go buy a Poogoe just to see if I can do it Never will I complain about Citroen rear arm bearings again !!
    9,185
    Guys,
    I thoght the BX at least would have been the same.
    Graham
    9,185
    The 205 GTi uses an inertia brake bias valve, as the car stops something in the valve moves forward and blocks off the rear brakes. Don't know if is adjustable, probably not.
    The Si has compensators built into the rear brake cylinders
    Graham
    16,374
    Graham
    The CX, BX and Xantia are basically the same. You just have one big sucker of a bolt, two bearings. The big bolt passes through the bearings and retains the arm. It's a reasonably easy job with the right tools, if (and that's a bloody big IF ) you can get the big bolt out and the bearing cage isn't rusted to it.... I'm sure these things get assembled with salty water instead of grease.
    very basically:
    --remove wheel
    --unscrew hose clamp, hydraulic line and remove suspension cylinder and sphere
    --unscrew and remove brake line
    --unbolt anti-roll bar (2bolts)
    --undo big arm retaining bolt and wiggle/curse/scream at the arm to get it out ....
    Could take as little as a couple of hours, or as much as days .... of excrusiating bloody frustration
    The bearings are just a standard SKF item, and can be purchased from the local bearing store.
