Dwell Meter Questions
Results 1 to 7 of 7
    Fellow Frogger! Peter J's Avatar
    Jul 2003
    Dubbo NSW
    198
    Default Dwell Meter Questions
    Hi all,
    I found my dwell meter in the shed today but the instructions are no where to be seen. Is it one clip to an earth and the other to one side of the coil and the induction pick-up on No. 1 spark plug lead?
    I can't remember now? Can anyone confirm that for me?
    And I know this question has been asked before, but if the dwell angle is too low do I open or close the points?
    Peter J.
    PJ
    12,256
    you need to put the red lead on the opints side of the coil and the black to earth
    to adjust the points it depends on the dissy
    some are externally adjustable and the others you need to take the cap of and adjust by loosening the screw and moving the fixed point of the points
    my advice is set the gap as per the manual and go from there
    1 x '98 306 GTi6
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    384
    Quote Originally Posted by Peter J
    Hi all,
    Peter J.
    Peter,
    If the dwell is to big the gap is to small and vice versa.
    Pete
    I am gunna get another 403 on the road........one day
    Jul 2003
    Dubbo NSW
    198
    Quote Originally Posted by PCOATES505
    Peter,
    Pete
    Thanks Peter and Rambo. Just one more question ... and probably a stupid one. Does this all happen with the motor running or in some static manner with the ignition on and the HT lead on the coil disconnected? I seem to recall it is measured with the engine running but I don't want to destroy my meter ... just checking?
    Peter J.
    PJ
    12,256
    Peter J.
    Peter
    you will need the engine running
    also remove the vac advance line, have the car at operating temp
    1 x '98 306 GTi6
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Peter
    To check that the vacuum advance is working. Re-attach the tube and point the light, (this assumes that it is a combination dwell and strobe light unit) and watch the marker advance/retard as the revs rise and fall, (slowly up and snap off throttle).
    On the unit I have you can dial in a set advance for a specific rev count and the marker will be at TDC, ((by strobe) all going well).
    If the cam lobes on the dizzy are worn, then setting the dwell to spec will give you too much advance. A wandering advance scattered TDC marker or secondary strobe point for the TDC marker can indicate uneven wear of the lobes or a bent dizzy shaft (different dwell for different cylinders-consistent readings)/worn bushes in the shaft (dwell up and down for all cylinders like a mad womanís under cloths), (you may need to mark a TDC point for each of the cylinders or one TDC and one BDC (@90DEG) swapping to each of the cylinder leads as need be). Donít panic it has to get pretty bad before you notice any change in the cars running.
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    Jul 2003
    Dubbo NSW
    198
    Thanks Fellow Froggers.
    Dwell meter all sorted. It is amazing how well amd engine runs when it is tuned properly!
    Peter J.
    PJ
