505 sti fuel pump
    Jun 2004
    8
    Default 505 sti fuel pump
    having problems with the electrical connections to the fuel pump
    fuel pump runs fine
    however keeps going dead after a few weeks
    when you play around or move the connectors fuel pump works again
    anyone know if you can improve the connections ( seems the plastic housing
    is the problem and prevents the connector from making a proper connection some of time
    i dont see the need to replace the fuel pump
    alanh
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    384
    Quote Originally Posted by alanh
    fuel pump runs fine
    alanh
    What connectors are you talking about? All the sti's I have seen have bolt on connections at the pump. It could be the tachometric relay playing up!!
    Regards Pete
    I am gunna get another 403 on the road........one day
    south australia
    225
    some times the terminals on the end of the wires dont sit into the post guided properly,its the plastic raised sleeve.take the terminals off and check if the wires are crimped in tightly to the terminals,a lot i see have been recrimped and work loose.make sure the terminals fit down into the recess and do up properly.you may have a sticking pump and by tapping it you a dislodging the impellor and goes for a while,this is not uncommon in old pumps.
    Fellow Frogger! pips's Avatar
    Dec 2004
    Behind you
    487
    Crimping is for loosers. Solder everything!!!
    Ever wonder why Mad Scientist talk to themselves? They know others just wouldn't understand.
    The software said "Windows 98 or better". So I installed Linux.
    1990 405 Mi16
