gearbox oil drain-205 gti
    Jul 2004
    nth balwyn, victoria
    1,428
    Default gearbox oil drain-205 gti
    how do you drain the oil from the gearbox of a s1 205 gti.
    is it the plug on the back of the diff or do you have to pull a drive shaft out?
    -BAZZ
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Quote Originally Posted by bazgti
    -BAZZ
    It should have a plug pointing towards the rear of the car and situated on the final drive (diff) section.
    It should have a square hole in the middle that will take an 8mm square key or a 21mm spanner (plug spanner size) on the outside of the plug.
    The filler is 19mm on the end of the box and to access, jack up, remove road wheel, remove inner guard and screw out. If you do the system I suggested, use 2 X 1 litre bottles that have spouts on the neck. Use about 500mls, drop the G70 in and shake and then tip the rest in.
    Put the second one in until oil starts to drip from the filler hole. Total capacity around 1.8 - 2 litres.
    Alan S
    Jul 2004
    1,428
    Alan S
    ta al,just as i presumed.-BAZZ
    Ipswich, Queensland.
    1,895
    I believe there was an update on the oil capacity on these transaxles, and the amount to be measured in is 2.5 L. Of course this raises the level to above the std. level plug on the end of the housing. I ran 2.5L in my 205GTI and 405s, without any drama. I am also a believer in the Nulon G70.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
