Bleeding 405 SRDT Diesel injector pump??
    Ballina
    9
    Default Bleeding 405 SRDT Diesel injector pump??
    Hi All
    I am trying to put an injector pump back into my 1996 405 SRDT and am having trouble with bleeding it properly. Also we have replaced the 4 injectors at the same time. Does anyone know how to do this? I would appreciate any help and guidance.
    12,256
    Quote Originally Posted by ksandra
    Hi All
    there should be a hand pump that looks like a balloon there somwhere and a bleed nipple on the top of the fuel filter/water trap
    loosen the nipple and pump the balloon untill fuel comes out and no air then tighten it up
    you may need to loosen each injector line as someone turns the car over and as each one has fuel leaking from it tighten it up
    once that is done all should be ok
    your pump may also have a bleed screw on the casing as well so same thing there when hand priming after you bleed the filter
    i haven't bled a 405 for a long time so this is a general rule for most diesels
    1 x '98 306 GTi6
    Ballina
    9
    thanks - we have got the car going but now it is blowing heaps of white smoke and running a bit rough???
    12,256
    white smoke = too much air for the amount of fuel the engine has bieng used which can also mean not enough fuel ie running lean
    make sure you have all necessary lines attached and they are all secure without any leaks allowing any axtra air into the system via vacuum
    1 x '98 306 GTi6
