Broken Key Lock.
Results 1 to 8 of 8
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,376
    Default Broken Key Lock.
    Just how would one go about removing a broken key lock mechanism on a 505.
    I tried to turn the key one day and it preety well, well it felt like it collapsed in the barrel.
    Either way, got a set in a car i can use, but stuffed if i know how to go about removing them "shrugs"
    Had a quick look the sarvo and it seems fairly well attached to the inner door frame, also.
    There seems to a mechanism that would be responsible for central locking still attached to the locking mechanism.. Is that indeed what it is? sits in the drivers door about half way down i suppose across on the right hand side with a black spring sealed in a shroud connected to the locking mechanics.
    Can i just get my hands on a middle locking switch, i geus it goes where under the drivers window winder switch in the middle consel where a spair space exists "shrugs"
    Anyway.. Cheers for your wisdom,
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    384
    [QUOTE=bowie]Just how would one go about removing a broken key lock mechanism on a 505.
    Hi Bowie,
    This is a very simple job, the lock is held in place by a U shaped clip, with a tang on one end, just lever on the tang with a long screwdriver until it slides out of the grooves in the lock and remove the lock from the door, there is nothing else to remove.
    Regards Pete
    I am gunna get another 403 on the road........one day
    Aug 2002
    3,376
    well i feel like an idiot..
    form my initiall inspection it looked as if it was welded
    lol Thanks for that
    5,312
    I agree, but don't lever against anything important, i.e. anything you will be refitting. I found it was safer to use a pair of pliers, and "jiggle" the clip. Towards the front of the car, obviously.
    Mike.
    Last edited by catshamlet; 20th June 2005 at 11:08 AM. Reason: don't know my arse from my elbow!
    5,312
    Default check the times, PLEASE!
    Quote Originally Posted by bowie
    lol Thanks for that
    My reply makes it seem that I agree that you're an idiot, but that's not what I meant. I agree with Mr. Pete, not you. That doesn't mean I don't agree with you. Give me a bigger spade, and I'll dig myself a deeper hole...............................
    Aug 2002
    3,376
    lol no problem catshamlet.. just get your boys in the baggy white to trip once and a while so we poor Baggy green Fans can at least not look so much as the idiot in question
    5,312
    If you've started to see little green men it's time for the men in white to errr, interview you...
    Good luck.
    Here's a good trick. Glue your bails together, that always fools them.
    Mike
    Aug 2002
    3,376
    well i finaly get around to removing em and swaping them over..
    only to find they are different..
    The older 505 lock i wanted to use is significatly larger to the barral in the 83 model 505 i have
    but low and behold, when i took the old one out i attack it with WD40 and it seems to be functioning again properly "shrugs"
    I did manage to break another two white hocks of my door trim tho
    Oh.. and thanks for the tip, ill pass it on via hero fax tonight
