Xsara VTS - replacement brakes...?
    Fellow Frogger! DJ-Studd's Avatar
    Apr 2003
    Victoria, Australia
    545
    Default Xsara VTS - replacement brakes...?
    Hi guys.
    I'll probably need new discs and pads in my '02 VTS soon. Just wondering if there were any "bigger brake" alternatives readily available in Australia at a decent price. I'd love something like this - http://lefrancaisconnection.com/citu...s.aspx?pid=491 - , but alas, the credit card isn't that big!
    Any suggestions? The car stops well as is (with the ABS, EBFD and all that), but I figure that if there is something better available that's just a bit pricier than the stock, why not go for it?
    Cheers.
    -- DJ
    Edit: I've had the brakes in the Xsara smoking before, so....
    -- DJ
    1000+ Posts TroyO's Avatar
    2,511
    If you are looking a putting in bigger brakes then you will need bigger rims as well. The standard 283 mm front disks and calipers only just have enough clearance with the standard 15" alloys.
    Troy.
    Apr 2003
    Victoria, Australia
    545
    Rats, I was hoping that wouldn't be the case. I like my rims
    In that case, any alternative discs such as grooved (etc) that will deliver better performance?
    -- DJ
    Sep 2003
    409
    standard size options include the EBC trackday groove disc with greenstuff pads
    big budget options include 17" rims (205/40/17) with the Tarox 350mm disc with Tar-ox 6 pot callipers. Ultra budget can upgrade these discs and pads to a hybrid ceramic disc with sintered pads.
    '04 Citroen Xsara VTS
    Mallala - 1:29.96
    Apr 2003
    Victoria, Australia
    545
    Thanks for that XsaraVTS.
    I might look at the EBC Trackday Grooved Discs and the Green Stuff pads. What would the life expectancy of these products be for road use?
    Ta.
    -- DJ
    1000+ Posts U Turn's Avatar
    1,761
    Quote Originally Posted by DJ-Studd
    Ta.
    -- DJ
    Save some $$$$ and get the DBA longlife slotted rotors instead. Just as good. Others here have done that. I've been using ferodo ds2500 pads. Expensive but phenomenal. Maybe a bit of an overkill for the street, but they're not hard on rotors either.
    Take the long way home....
    - 306 gti6
