Peugoet 505 Brakes gone Soft!
Results 1 to 24 of 24
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,376
    Default Peugoet 505 Brakes gone Soft!
    Just recently, within a space of 24 hours the brake pedel on my 505 has become extremely soft
    Previously, a simple touch and press pushing it a mear 2cm would start the braking procedure occuring. Currently i have about a foot of pedel play just before it hits the firewall it engages.
    Fluid level is chocoblock.. cant see any leaks anywhere.. Surely if i had extrmely low presure fluid would be getting out.
    what could be causing this??
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    A good guess is an internal seal/non-return valve, in the master cylinder.
    Easier to replace than to Kit.
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    Fellow Frogger! 123abc's Avatar
    Feb 2005
    brisbane
    358
    i once had the same problem.....it was the flexible hose on the front, the one that pokes throught the wheel arch, it was balooning when i pressed the pedal but it wasnt leaking.....
    also check the flexible hoses at the back of the car too.....
    failing that if your sure there's no leaks then it must be one of the cylinders, either the master or one of the slaves, they might be bypassing (fluid moving around past the cup seal and returning when you release the brake)
    Picton NSW
    1,412
    Quote Originally Posted by 123abc
    Had not considered a balooning hose. (I have seen it before, just never happened to me).
    The slaves either stick or leak, the fluid cannot return to the cylinder once expelled, (the cup seal only keeps the grit out).
    Firstly try a good flush and system check.
    2003 T5 307 HDI
    2013 LandRover90
    Aug 2002
    3,376
    balooning.. indeed would have never thought such to possible..
    Cheers for that.
    Feb 2005
    Glen Iris
    71
    The master cylinder is the liklely culprit. As previously mentioned,
    'A good guess is an internal seal/non-return valve, in the master cylinder.
    Easier to replace than to Kit.'
    Fluid seeps past the internal seal/non-return valve. A master cylinder costs about $120 ???...easy to replace. Bleeding the brakes will be the main task.
    Scott
    Feb 2005
    brisbane
    358
    Quote Originally Posted by Gamma
    fluid can bypass the internal seals in any hydraulic cylinder if the seal has hardened/worn, pneumatic cylinders are even worse for it....see it all the time at work on large hydraulic cylinders......think of it like a cylinder turning itself into a shock absorber, instead of pushing fluid out into the line, it simply moves it from one side of the piston to the other and bake again.....more likely in a master cylinder though, but still possible in a slave sylinder
    Feb 2005
    brisbane
    358
    Quote Originally Posted by Scott 505 gti
    Scott
    if it is the master cylinder, a seal kit costs about $12 - $15, and takes about 30mins to replace............personally i wouldnt be changing a whole cylinder unless the bore was pitted
    but thats just me...lol....
    Aug 2002
    3,376
    well i have a spair one in the shed either way... have no idea what condition it be in.. looks like it hasnt been driving since 92, most likely that the seals in this one would be usless to??
    Picton NSW
    1,412
    If the kits are that price, ($12-15) and available and include all internal components, then go for it.
    The bores are the worry, any sign of pitting or scoreing then, "out dammed spot".
    The spare of unknown age and condition is not a bolt-on without a re-kit.
    2003 T5 307 HDI
    2013 LandRover90
    Feb 2005
    brisbane
    358
    yer, a seal kit will come with a couple of cup seals, a few little plastic washers and a little seal for around the plunger
    yes, i agree, the unknown spare probabley became a spare because it was stuffed............
    however before you pull everything apart, check all the flexible hoses while someone sits in the car and presses the brake.......
    check around the litle compensator valve thingo at the back, see if it's leaking, but if you say the fluid level is good, then i doubt its leaking........
    Perth Western Australia
    2,678
    Default 123abc
    Is that 30 minutes to remove, rekit and replace in that time?
    To do the job properly a proper clean up of the fluid reservoir, pistons and the cylinder bore is a must. The latter usually requires a light hone to determine its condition. Then very carefull assembly.
    Even in a professional situation you would be looking at a minimum 1 hour job.
    Although in the above it would simply be fitting a new cylinder.
    A small tip, to minimize the bleeding process carry out a pre-bleed on the bench then with the pipe holes blanked off and the reservoir full fit the assembly loosely to the car. Fit the pipes to the cylinder, the fluid will bleed past as this is done. Tighten the pipes then the mounting nuts.
    Providing no air has been pumped through the system you may get away without bleeding. x2
    Feb 2005
    brisbane
    358
    Quote Originally Posted by Wildebeest
    yes, half an hour,
    to remove ( what is it, two bolts and three brake lines)
    dis assemble (1 lonely circlip, two lock washers, and a little blade screw in the first piston)
    clean and inspect, (rag on the end of a little bit off dowl wood/finger)
    reassemble (slide all the bits back in with new seals)
    refit circlip
    refit to car, fit brake lines loosely, fill with fluid, wait a few minutes then tighten brake lines..........bleed front brakes if nessisary
    thats how i did mine.......works like a charm, estimated half an hour
    and a master cylinder doesnt need a light honeing unless it has polished spots (where the rubber from the seal has desintergrated and stuck to the bore). if it has big gouges or pitting, then you can either get it resleeved ($50 for a stainless resleeve when i did the ute, wouldnt be any differant for a pug, just a quick machine job on a pre bored blank bit of stock tube)
    i would suspect that there would be mechanics out there who would prefer the "new cylinder method"............two bolts and three brake lines then bleed the brakes, that'll be 70 bucks labour thanks (on top of parts) i dunno what auto electritians are like, as a know absolutly nothing about electrics...but some mechanic shops, ya gotta wonder aye.
    2,678
    Default 505 brakes.
    yes, half an hour,
    refit circlip
    123abc,
    Chacun a son gout.
    Aug 2002
    3,376
    Well indeed... i gave my mechanic a call and he's like. .yeah.. have to order it in.. $200 and an hour later you'll be right
    i even asked him if a kit will do and hes like.. yeah nah! we dont bother with kit.. $150 for that part, $50 in labour you'll be right..
    I dont have that cash...
    If it isthe master valve that has broke... how long can i drive on the slave? before im left with no brakes? and where can i order in kit from? Repco? Super Cheap?
    Picton NSW
    1,412
    To risky to drive anywhere.
    A brake problem is not one to be ignored.
    Do not move the car until it is fixed..........
    It is possible that you may suffer a complete loss of stopping ability, while heading down hill into a Merc and onto a childcare centre on seniors day.
    And as for the Hand brake on a 505..... I have one and it works as well as it did when it left the factory.....Where is the parking brick....
    2003 T5 307 HDI
    2013 LandRover90
    Aug 2002
    3,376
    parking brake works ok... just have to ask hulk Hogan to pull it up for ya
    Feb 2005
    brisbane
    358
    123abc,
    Chacun a son gout.
    et pour certains, il peut être aquired le goût
    Feb 2005
    brisbane
    358
    Quote Originally Posted by bowie
    last time i did it, it was about 15 bucks, however, after a quick phone call to supplier, it appears that depending on the type of cylinder (there are several, ATE, Gerling, Bendix etc.) the price may differ, but he assured me that the most expensive kit is the kit for the most rare cylinder, which is just under 50bucks................now, chances are that you have a more common cylinder, esspesially if it has been changed before (more then likely) so the price will be around 30 bucks or so.....
    mine just happend to be 15bucks or so ( i cant remember exactly) but yer, sorry for any confusion, either way its a lot cheaper then the other option......however....
    before you go and order stuff, if you're sure its the master cylinder, pull it apart to make sure that it isnt pitted or whatever first, otherwise you'll find yourself with a kit that wont fix the problem..........
    you're in newcastle, so i dunno any suppliers down there, but i get parts from this bloke(07) 33446624, and he sends stuff everywhere so it shouldnt be a problem......otherwise someone from your area should be able to help with a supplier down your way......
    2,678
    Default 505 brakes...
    123 abc.
    Touche.
    Je dois jeter mon dictionnaire Francois d`ecole.
    Feb 2005
    brisbane
    358
    123 abc.
    Touche.
    j'ai juste triché et ai utilisé le traducteur d'altavista.
    Picton NSW
    1,412
    Je préfère le worldlingo
    www.worldlingo.com
    2003 T5 307 HDI
    2013 LandRover90
    5,312
    Vraiment, nous avons ici les derrieres intelligents.
    Mais les accents?
    Dommage, ils sont merde
    Aug 2002
    3,376
    getting spamed by the french...
    didnt see that one comming
