auto transmission problem
Results 1 to 10 of 10
    ferntree gully
    21
    Default auto transmission problem
    hello fellow froggys i have a 405 4 speed auto , whats happenend is ive lost all foward gears ,i only have reverse i dont know what the problem may be theres plenty of oil in the tranny the selector on top of the box moves so the cable linked is ok but you start the car select any fwd gear and nothing yet it goes into reverse no problems.try reversing around round abouts the only way i could get home was to drive down all the back streets in reverse please some one out there help with some info please please dont say i need a new transmission please some one out there must know what it may be
    Dec 2002
    2,528
    Sounds like you've lost the forward clutch. Not uncommon in the 3/4HP22xx series (505 3 speed - 505 4 speed - 405). Usually caused by lack of servicing, or as I saw one, dumping the car into gear from neutral at about 5000 RPM once too often
    Unfortunately a rebuild is going to cost a lot. Good replacement trannys for the 405 are hard to come across, and expensive.
    You need to ask yourself, how much is the car worth to you?
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    You say the oil level is right, but how are you checking the level?
    Alan S
    Dec 2002
    2,528
    Alan S
    If there was a problem with the oil level, chances are you wouldn't have reverse either. If there's enough fluid to drive the torque converter, there's enough fluid to drive it into gear.
    But yes, you need to check the level with the engine running and the transmission warm.
    Scotty
    ferntree gully
    21
    thanks guys for your help the tranny oil is right but i heard theres a small filter in the box this might be clogged does that soound right to you. but i really say thanks again
    Dec 2002
    2,528
    Quote Originally Posted by PUG_405_7000
    Again, if the filter is blocked, you won't have reverse gear either.
    Scotty
    5,066
    Can you do the work yourself? It may not be that exoensive.
    Good Luck
    ferntree gully
    21
    Quote Originally Posted by JoBo
    Good Luck
    thank you sounds right about reverse but you never know i'll post result as soon as i give it a go . picturures would be handy to know exactly what im looking at do you know of any links regards troy
    5,066
    For parts try VM TRANSMISSION PRODUCTS LTD in the UK. 0208848 9911
    I dealt with Kirk, but you may be getting better prices in Aus or NZ.
    ferntree gully
    21
    thanks very much its a shame that the tranny has possably gone we love that little car but being true to pugs i bought my son a 505 sr which is a one owner but i dont know what to do with the 405 i cant sell it with a bodgy tranny regards danny
