405 Mi16 as a tow car?
Page 1 of 3 123 Last
Results 1 to 25 of 53
    Member Pugknut's Avatar
    Oct 2002
    Melbourne, Victoria.
    90
    Icon5 405 Mi16 as a tow car?
    Hi all,
    wonder if anyone can advise on the max legal weight you can tow with one of these and what people think of one as a tow car. I am looking for something to drag my little rally car around (it weighs just over 900kg) and I figure if I knock together a light weight trailer, this could be a good combination.
    Hoges
    Jun 2003
    Rowville
    103
    I used a 1905cc MI16 as a tow car for my Formula Vee (before I chucked the Vee into the backdrop) for a number of years and found it a pretty good tow car.
    I also towed a pop top caravan with it again without any real problems. Between towing the Vee and the van up and down the east coast and South Australia the MI16 covered around 15,000 km towing without any problems.
    The most important issue is to keep the ball weight within the Peugeot limits. I seem to recall that this is around 70 kg. I would also recommend electric brakes on the trailer.
    JYD
    7,446
    It's a MUCH better tow car if you advance the inlet cam with one of Owen Wuiilemin's offset cam keys.
    Oct 2002
    90
    More torque then from this mod I take it? Sounds like it might be just the thing, now I just have to:
    a: Convince her indoors that it is a good plan
    b: wait for the right one to come along and
    c: get rid of the Patrol.
    Thanks for the advice guys.
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    How would the rear end cope with a trailer? When i have a couple of decent sized people in the back it sits pretty low...
    405 Mi16 - Sold - Now back
    205 Mi16
    505 GTi
    Aug 2002
    1,290
    Quote Originally Posted by JY Dog
    JYD
    Hmm 70kg ball weight, which should be 10% of the trailer weight = approx 700kg. 900kg for the car with no trailer, you do the maths.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Fellow Frogger! WRCPUG's Avatar
    May 2002
    Glen Iris, Melbourne
    1,035
    My old man had to tow a 1950's Mk5 Jaguar (over 1500kg+) and he used his S2 Mi16 to tow it.
    He said it was great for towing and was very surprised at how it had no trouble at all even up hills. He had to tow the car from country victoria to inner melbourne.
    PEUGEOT 306 GTi6 (1997-1999 HYBRID)
    105.4kw (141HP) ATW
    2:09 Phillip Island (Toyo Street Tyres)
    2001 YAMAHA YZF-R6
    119HP
    1993 MITSUBISHI 3000GT Twin Turbo
    300BHP
    STOCK-14.006 @97.4mph HEATHCOTE
    STOCK-1:15 CALDER Long Circuit (Stock Street Tyres + Stock Pads :banghead )
    (For Sale)
    Oct 2002
    90
    Quote Originally Posted by cruiserman
    Hi Cruiserman,
    where does the "should be 10%" come from? Is this a typical design / loading criteria, or rule of thumb?
    Hoges
    Ipswich, Queensland.
    1,891
    10% is a considered rule of thumb. Saying that I towed my 650Kg 4CV on a reasonably light trailer up to 100kph with my 306 with no difficulty. The trailer brakes were well set up, overide Falcon discs and made the trip a pleasure. I did juggle the position of the 4CV, but did not check the towball weight.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    Jun 2003
    Rowville
    103
    The accepted range (by specialist magazines) for ball weight is usually between 7 - 12% of trailer weight. I currently tow a trailer carrying a Clubman with a ball weight of 7% and it tows very well at 100 kph. As I said I recall the figure for the 405 to be around 70kg but this is from memory. However from my experience with the MI16 a few kg over was not a problem.
    The main thing for safe towing is loading the weight correctly and obviously axle location. From my experience I would strongly recommend the use of electric brakes instead of over ride units.
    JYD
    16,370
    Getcha self a Citroen Xantia CT turbo and don't worry about all the other crap. Any ball weight will be ok, so long as you keep about 10% of the trailer weight there.
    I imagine an 8valve would tow better than the 16valve. I have a 17' (ultralight) caravan and the 8valve slugomatic Xantia tows it ok. Sometimes on constant gradiants will restrict you to 80-90km/h though.
    Nothing matches the old CX though .... If you really want to tow a nice weight (for a car of it's size/weight... Obviously some sh!t for brains womens 3ton tank will probably tow better).
    Oct 2002
    90
    ... Obviously some sh!t for brains 3ton tank will probably tow better).
    Yeah, I've already got on of those (GQ PAtrol, 4.2l diseasel) but I'm thinking to replace it with something a bit cheaper and more economical for daily use. Then I can use it for PCCV speed events, motorkhanas etc. which the triumph is not suited for. Anyway, I appear to be losing the battle with the other half on this one " you want another car to do events in... "
    Hoges
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    as mentioned above, towball loading gives you stability and prevents trailer wondering behind the car.
    General accepted range of loading is about 8~10%. If having 75kg tow ball loading as MAX acceptable, would give 405 about 750~900 range.
    Any trailer over 700kg (gross weight) must have independent braking system (override or electric).
    which brings us to what can tow that. I have seen 407 used as a tow car, and it apperas to sit a tad low in the ass end but the owner is happy (until something breaks?). My commy drops a tad (50mm) but is well within the towing limits for the ball loading and mass of trailer. Still returns about 12L/100kms when towing.
    Most of the people at supersprints do use larger vehicles for towing.
    7,446
    Quote Originally Posted by tekkie
    Yes, I use my trusty Patrol!
    16,370
    Simple physics, the bigger the tow car, the better it *should* be towing the same weight. The likes of the 405/BX I reckon are simply to light (though the crazie [email protected] in the UK tow things like 19' caravans with BX's So they can't be to bad).
    If I had something heavy and big that I needed to regually tow, a turbo diesel 4wd would be on the top of my list. A little light weight sprint car I could tow effortlessly behind my CX. A standard falcon or commodore will tow these types of things easily too (a new fowlcan will tow 2500kgs I've heard).
    The best bit about Citroens, is you can put some decent ball weight on them if required and they simply self level, the back of the car justs lifts to the correct height. Though the whole towed vehicle looks really good and level/stable this doesn't mean it can't be overloaded. I think the CX is only allowed to tow 1500kgs according to my factory manual, however I've had things like massive 850+kg car trailers with 1.5ton Citroen DS's on them behind it. They tow really well and it doesn't look overloaded ..... But simple physics says a load that heavy could go wrong really fast if something happened (eg: the trailers brakes not working, trailer get the speed wobbles/shredding a tire etc...).
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    This is worth a read based on others experiences.
    http://www.andyspares.com/discussion...TOPIC_ID=14443
    Alan S
    Ps. Just remember when these guys talk speeds, they are referring to MPH not KPH. They still work speed and distance in miles over there.
    Aug 2002
    1,290
    Where it all becomes very interesting is if you have an accident, insurance companies have the task of trying to weasel out of any claim. If you are outside your towing limits kiss goodbye to your claim, and hope you didnt hit anything too expensive to repair.
    Neil
    '94 405 SRBT
    '76 CX Super
    '05 WL Statesman
    Oct 2002
    90
    I never even considered a Citroen being a pug man, but might have to reconsider based on that information.
    Many thanks to all of those who have posted in with their first hand accounts of towing with a 405, but is there someone out there who can answer the question fom the vehicles rated capacity? In Victoria, the legal load (if not specified by the vehicle manufacturer) is 1.5 times the towing vehicle weight, but I am sure that the 405 will have a manufacturer specified towing capacity.
    Come to think of it, what about the Citroen's rated capacity?
    Hoges
    jgp
    jgp is offline
    Member jgp's Avatar
    Apr 2004
    brisbane
    46
    Quote Originally Posted by Pugknut
    Hoges
    I have the owners handbook for my s1 if you can tell me the type code number for your car i''ll look it up. eg 15BDF... or 15BDD.... its in the VIN number.
    90 405 MI16
    96 406 ST
    7,446
    Hoges
    But they're bullet proof and cheap to run! It would be a false economy to swap it for another tow vehicle. Just keep driving it until it's dead. I've got 345 000 on mine now, still going strong.
    8,923
    The limit on a BX is 1100 kgs according to the handbook and it's load capacity is 1500 kgs.
    I can't speak for a Xantia, but being a somewhat heavier vehicle I could imagine it would be higher.
    Alan S
    16,370
    Hi Guys,
    actually the Xantias tongue limit is very low .... And due to this bloody thread I've just realised why They have no doubt given the Xantia the identical towing capabilities of the 406 ie: they seem to have forgotten the hydraulics will take far more drawbar weight than a 406 with [email protected] suspension.
    My Xantia can't legally tow my fathers 16' caravan as it's drawbar weight is far to heavy (though no doubt it would tow it extremely well.... Especially if it was a V6 or CT turbo).
    Check the tow ratings well before purchasing the Xantia. I'm bloody positive it'll tow any you wish with supreme ease (within reason), however you insurance will be void if your outside the specs stamped on the towbar (bloody poogoe stuffing everything up .... Even the old DS could tow 1800kgs according to my handbook).
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    The folks at CARASEL explained to me that a 405 towbar and a 306 is the same model and its rated at 75Kg Max tow ball weight. My S16 and your 405 have similar power power/weight characteristics and I can say with experiance that my S16 made a poor tow car.
    Getting of the line smoothly will be your clutch leg work out... - Chris
    ... ptui!
    8,923
    You can haul all knds of things with a CX
    This log is twice the length of the car. AndyN saw it when he was here and was a bit stunned when he saw the size of it in the flesh I think.
    Alan S
    Fellow Frogger! chris's Avatar
    Jan 2005
    Sydney/Marsfield
    376
    What's with everyone going on like 4WDs make good towcars? In my observation they're not at all the wasp's nipples. Every time I see some vehicle struggling up a hill at about 65 km/h, wallowing and bumping with something moderately heavy in tow... it's a 4WD. This is really noticeable at night, when you're getting blinded by d!ckhead's "dipped" lights because the soft rear suspension on their high-centre-of-gravity beast is squished down to the floor...
    They're heavy, so they don't notice a small or medium sized trailer so much, but they always look like an accident waiting to happen with something big on behind
    GS 1220 break. Beige cars go faster
