starting problem
    Member fat bastard's Avatar
    Nov 2002
    Perth WA
    114
    Default starting problem
    Need some help please on a Bx 1.9 16 valve (MI16)
    Intermittent ignition usually when starting but also whilst driving. Definitely ignition, not fuel. Engine turns over but will now not start at all! Thought that it was rotor/distributor but is neither. There's only a faint spark from coil (Can hold unprotected coil lead whilst turning over). Checked wiring from crank sensor and ignition module seems ok. Was going to replace coil but have been told that peu/cit coils go forever.
    Present: 406 petrol 2.0 turbo 97(GB Import), 205 gti 1.9 89, Yamaha TZR250 3xv 93 (Jap Import)
    Past: 205 gti 1.6 1988 (Singpr Import), Citroen 1.9 BX16valve, 405 1.9 mi16, 405 2.0 mi16,
    205 si 93, Mini GT, Datsun SSS x3, Dodge Ram, kingswood, Yamaha TZR250 2ma x2
    Hey mate...You've left your Barina's lights on
    Nov 2002
    Yarrabilba, Queensland
    2,755
    I had a similar problem in a car years ago. Would crank but not start, and the starter was found to be faulty.
    The way we worked this out was to put a relay in the starter circut, fired by the ignition switch, that switches power directly form the battery to fire the starter. This will tell you if the starter is drawing too much current for some reason, as by doing this you take it out of the start circut and feed it directly and solely, allowing the coil to power up enough to fire the engine.
    Ahh, didn't read the post closely enough. Mmm if it's whilst running too, it probably isn't starter.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Dec 2002
    2,528
    Coils do give up. I've replaced 2 on 2 different Mi16s.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    It sounds like a coil, but before you lash out on one, I remember someone having a similar problem a few moths back and it turned out to be the coil overheating due to it not having heat paste on the back of it that allows the heat to be dispersed via the heat sink effect on what it's bolted to (the plenum).
    The other option of course is the LT plug into the coil (the one with 4 wires in it) either loose or shorting. It is common for this plug to cause intermittent misses at low cruising revs and not impossible for it to cause an engine to cut out completely or not start if either of these problems were to arise during either starting or running.
    Alan S
    Nov 2002
    Perth WA
    114
    thanks everyone, I'm on to it after work today.
