power steering seals
    Tadpole kimbo's Avatar
    tamworth nsw
    22
    Icon9 power steering seals
    i need to put new seals in my power steering as it's leaking really badly. can anyone tell me if there is a special type of seal for the or can i buy them from a auto place
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Kimbo,
    What type of car is it?
    Is the leak form the rack or the pump area?
    I ask because on both the 505 wagons we've owned, we had the odd p/s fluid leak.
    A cheap fix, is to drain ALL the fluid out, and replace it with Lucas Power Steering Stop Leak.
    http://www.lucasoil.com/products/dis...tid=2&loc=show
    This isn't a paid ad either.. it does work exactly how they specify. It will stop the leaks. I also found it quiets noisy racks and pumps too. Buy the 1 litre bottle, most Repco stores stock it.
    Chris.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Aug 2003
    371
    Quote Originally Posted by kimbo
    If its Pug 505 /604 seals you are after, they seem to be special as they are very skinny (ie: not wide). 10 years ago (at least) I tried at my usual Bearing / Seal places & they didnt have them then - but may have now.
    You can get seal kits from places like EAI & they are actually not too expensive.
    There a lots of posts about doing this, check the archives before you dive in, as it may be something differnt (on 505s )
    tamworth nsw
    22
    it's a cx 2400 citreon and the leak is from the rack area
    CitroŽn Tragic UFO's Avatar
    9,697
    You should post this in the Citroen forum. Alan or Shane are more than likely to have a fix for it.
