head bolt tension
Results 1 to 24 of 24
    Aug 2003
    nambucca heads
    11
    Icon5 head bolt tension
    What is the head bolt tension on mi16 1.9. the book says to use an angle guage which i dont have. Just thought a lbs tension would be easier.any advise would be appreciated.
    regards petera
    Fellow Frogger! mattg's Avatar
    Feb 2005
    Port Macquarie NSW
    191
    Teng Tools torque rench have an angle guage on the ratchet head. not shure if this help but they are great value at around $100 and are indervidualy calibrated.
    Matt
    9,223
    If you get a simple plastic thingy from your local newsagent you can cut a hole or a relief in it so that you can put it on your extension bar and work to the right angle from there.
    'Thingy'? Yeah, I'm trying to think of the right word... it just won't come to mind... but you know what I mean, the half round things with the degrees marked on them up to 180?
    12,256
    all you need is a piece of wire clamped onto the externsion bar and a piece of cardboard with the angles marked on it
    1 x '98 306 GTi6
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    Protractor!
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Aug 2003
    nambucca heads
    11
    Default thanks
    thank you , will give it a try.
    regards petera
    9,223
    Originally posted by pgti6
    Protractor!
    Yeah, that's the one!
    You use that to set up your expensive bit of bent wire...
    7,448
    I think from memory it's 300 degrees, after the first two pretension sequences.
    I don't use a protractor though, as a Torx bit has 6 edges anyway. I use a long breaker bar and it's very easy to work out where 300 deg. is before you start the final tighten of each bolt.
    Someone sent me an email with an alternate sequence. I'll see if I can find it
    May 2001
    1,612
    Petera,
    Don't forget to measure the length of the removed head bolts-if any have stretched longer than the specified length ( I think it's 176.5mm from memory), you'll need to replace AlLL of them.
    Jeff
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    Aug 2003
    nambucca heads
    11
    Default new bolts
    Quote Originally Posted by pgti6
    Petera,
    Jeff
    thanks jeff I bought new bolts. just to be sure.
    petera
    12,256
    Petera,
    Jeff
    i thought they all had to be replaced as a matter of course anyway
    1 x '98 306 GTi6
    Perth Western Australia
    2,678
    Default head bolt tension
    Peter,
    I would like to be around when you do the final 300 deg. pull!
    If the engine is in the car it should be manageable. If mounted on a stand you will need half a dozen strong lads to hold it down
    12,256
    Quote Originally Posted by Wildebeest
    Peter,
    very true
    bad enough doing 120deg pull on a PRV
    much easier in the car
    in fact when i built the 604 engine a while back 2 of us lifted the block in by hand and i then set to and built the engine up from there once it was in there for the rest of the day
    1 x '98 306 GTi6
    19,055
    Default Tight Head Bolts
    Peter,
    Hold the socket bar and turn the engine stand ?
    7,448
    Peter,
    I would like to be around when you do the final 300 deg. pull.
    As long as the stand is pointing the right way and you put moly on the bolts, it's fine. I've given up on 2nd hand bolts. New bolts will pull up easily, but old bolts creak and grone, regardless of their length. I've had one break and it's not a pleasant experience.
    7,448
    "The tightening sequence recommended by Peugeot Sport for the
    Gr.A MI-16 cars factory-spec. (309 GTI 16S Gr.A) - it can be used on any alloy block XU engine running a very high CR and a special steel gasket:
    1) new bolts unconditionally !!!
    2) lubricate bolts (grease on threads, motor oil under head/spacer)
    3) tighten all 10 bolts (in the "spiral" sequence) to 2 mdaN
    4) tighten all 10 bolts (in the "spiral" sequence) to 4 mdaN
    5) tighten all 10 bolts (in the "spiral" sequence) to 6 mdaN
    6) loosen bolt nr.1 and tighten it to 8 mdaN
    7) repeat point nr. 6) for bolts 2-6, and stop.
    8) loosen bolt nr.7 and tighten it to 6 mdaN
    9) repeat point nr. 8) for bolts 8-10, and stop.
    10) that's all. No further re-tightening is needed.
    The spiral sequence is:
    exhaust
    9 5 1 4 8
    O O O O
    10 6 2 3 7
    cambelt side flywheel side
    9,223
    So this isn't 'torque to yield' Peter?
    What's the meaning of this strange business with the lesser tension to the four outer bolts?
    7,448
    I didn't say I did it that way. Notice it's in quotation marks.
    9,223
    Oh, I noticed that all right...
    So assuming you are quoting from some official manual or whatever, why do you think they might lessen the torque on the outer bolts?
    And why isn't it done by the normal 'torque to yield' method?
    2,678
    Quote Originally Posted by peter a
    regards petera
    petera,
    Had you already removed the cylinder head before you found that an angle gauge is a necessity for replacing the head?
    Im staggered to read in these posts how owners get stuck into different jobs without reading up on what is required and when good advice is offered will question it!
    In order to use a torque wrench instead of the degree plate to replicate a 300 degree pull would require a wrench calibrated for use on large earthmoving or industrial gear.
    Peter T,
    The convoluted head tightening procedure provided for Group A racing Peugeots could be explained by their design.
    I understand that the racing engines have the head layouts reversed ie exhaust at the front inlet at the rear. I believe also that the engines were built by an outside specialist, Cosworth? comes to mind.
    These specialists would have their own head tightening procedures.
    Aug 2003
    nambucca heads
    11
    petera,
    Peter T,
    wildebeest
    calm down. I have not questioned anybodies good advice. And yes I did read the haynes manual. But I have found from past experience it does not hurt to seek others opinions.Which have helped me in the past
    petera
    2,678
    Default head bolt tension.
    wildebeest
    petera
    petera,
    Apologies for my seemingly pointed comment, proof reading and re-wording should have been in order.
    Suitably chastised,
    Yours, Wildebeest.
    9,223
    Just a small point, peter a... don't look for opinions, look for experience...
    There's quite a difference. Someone who's never done the job can have an opinion, but they certainly don't have the experience.
    Aug 2003
    nambucca heads
    11
    Ray .
    thank you, point taken.
    petera
