205gti idle drop
Results 1 to 10 of 10
    Jul 2004
    nth balwyn, victoria
    1,428
    Default 205gti idle drop
    i have noticed that when i put on the lights and wipers and heater fan i get a slight drop in revs.
    now by the multimeter ,this is only a 1/2 volt drop when everything is put on at idle.
    my voltage meter is the battery clamp so its hard to read when driving.unless someone crawls under the bonnet as you drive and as we know,that aint a great look.
    i would asume the battery or alternetor is to blame ,but its a brand new 2 week old battery and the alternator reads 14 volts at idle and slightly over when revving so im assuming that they are 0k.
    any ideas or am i just obssessing as usual.
    or is this a sign of things to come.
    ps .it did the same thing with old battery.
    BAZZ 205 GTI
    Fellow Frogger! casnell's Avatar
    May 2004
    Heidelberg/melbourne
    912
    Quote Originally Posted by bazgti
    BAZZ 205 GTI
    I think it's just extra load from the alternator putting out more. I've seen the kw drop on a dyno just putting the headlights on...
    205gti
    Jul 2004
    1,428
    Quote Originally Posted by casnell
    yeah this is what i thought but was just fishing for opinions.ta mate-BAZZ
    86
    BAZZ 205 GTI
    Bazz,
    My 205 does the exact same thing. It idles fine up until I put the lights on, the revs then drop slightly. Ive got a new battery in the car and a freshly recoed alternator as well. Its left me puzzled as to what can cause this.
    Damien
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Dodgy earth continuity??
    Alan S
    Jul 2004
    1,428
    Alan S
    thats a bloody good point and a good place to start looking,damn these bloody froggy electrics and wiring.
    thanks alan-BAZZ
    Jul 2004
    1,428
    Quote Originally Posted by MR_205Mi16
    Bazz,
    Damien
    ah good to see im not just obbsessing then.-BAZZ
    Jul 2004
    1,428
    i went and cleaned the negative terminal on my new battery by scuffing it up with the battery terminal and pole cleaner i have .i also scuffed up the inside of the battery treminal and got about 1/2 volt up from before.
    its still a tad low when idleing with all things on but its not as bad.
    seems like the earth was the trick.im looking into it further .-BAZZ
    Fellow Frogger! WAUTY205's Avatar
    Jun 2004
    Devonport, TAS
    181
    Any car is going to drop idle speed when the alternator kicks in. The power has to come from somewhere. Same as Air-con.
    I wouldn't worry.
    -Will
    1990 205Gti
    1976 504 rally car (currently out of action)
    Jul 2004
    1,428
    Quote Originally Posted by WAUTY205
    I wouldn't worry.
    -Will
    i agree,but it was dropping TOO much and made the idle very bad.
    ive fixed alot of the problem by the above method.
    it now drops but not unacceptably
    -BAZZ
