Cam belt change in 405 Mi16 1.9
    1000+ Posts Warwick's Avatar
    Nov 2002
    2,664
    Default Cam belt change in 405 Mi16 1.9
    What do I need to know about this in advance guys? Any tricks?
    I'm doing this as the water pump is knackered.
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    Quote Originally Posted by Warwick
    1. Get some 6mm mild steel rod to hold the cam gears in place,
    2. 2 new belt tensioners,
    3. An 8mm (I think), but same size as the square on the sump plug, to adjust the tensioners
    4. New cam belt,
    5. Tube Permatex to seal the new water pump
    6. Bandages for the skun knuckles you'll end up with
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Fellow Frogger! enthused!'s Avatar
    Jul 2004
    Sinney
    439
    and make sure you tighten the tensioners the right way (its actually the WRONG way)
    otherwise your cam timing will be waaay out.
    have a look at this thread:
    retarded
    1992 mi16 1.9 litre - it's a love hate realtionship.
    whatever you do NEVER tell anyone your car is reliable. doesn't matter how much wood you touch!
    previous cars: peugeot 306xt, peugeot 205si, renault 20, renault 12 - sedan and wagon, renault 25, alfa 155 twin spark
    7,448
    You also need to lock the crank with an 8mm dowel (or drill). With the two cams and the crank locked, you can't go wrong.
    On completion, remove the 3 dowels and rotate the engine through 720 degress. The dowels should all slip straight back in as verification.
    I don't use any goo on the water pump. Just clean faces and a gasket.
    1000+ Posts rustymunga's Avatar
    Mar 2005
    A galaxy far far away....
    1,078
    Icon10
    Ha! PeterT I found you!!
    now its just Mr Wolly (alias) to go!
